I've bought myself a carver cascade 2 water heater off eBay but can someone please tell me the correct amp switch spur I need to buy, thanks.
Sean.
Sean.
ProfJohnL said:You should be using a standard 13A fused spur isolating switch. It should be a double pole. and you should fit a 5A cartridge fuse.
Woodentop said:ProfJohnL said:You should be using a standard 13A fused spur isolating switch. It should be a double pole. and you should fit a 5A cartridge fuse.
One minor comment - it should be double pole switched.........
