Carver Cascade 2. No Water from hot tap & pump on
Nov 21, 2016
17
One last question for you John and then I'll be out of your hair I promise! It is an unrelated question though, so if you think it's better in a new post, please let me know.
I have a main switch in the van. In this picture all the switches are set to what I'd call the off position apart from the main on/off switch, which is on.
As I understand it, this switches from using the car battery, to the leisure battery, but I have a couple of questions about the car/van switch:
When should I use which? Should it be in the off position (van, as it is in the photo) pretty much always, unless I need emergency power from the car battery because the leisure battery is dead?
Should it be on car if I'm driving? I do have a fridge in the van which I think can be used when the engine is running? I don't need the fridge anyway, so I've left that alone and I think on the fridge itself it's just set to be off.
If I'm connected to mains hookup, I'm guessing I want the main switch to on, and the car/van switch in the van position to charge the leisure battery?
If the car/van switch is set to car, does it charge the car battery instead of the leisure battery when hooked up?
Do you know of any manuals or anything? (I looked but I didn't find anything). Sorry for the basic questions, but it's been very hard to find information using such generic keywords! Thanks a lot!
4,465
Hello Ryan,
It's been great to have a poster who has gone into considerable detail about the the nature of the problems and posted some useful photos. Based on them, I have been able to make what I hope are useful observations and suggestions.
It's always wise to try and obtain user manuals for appliances so you can find out how to use them properly. Its worth trying the appliance manufacturer for copies. Sadly I do know that based on the apparent age of your Cascade, several appliance manufactures are no longer active in the industry. so you have to search for specialist service companies, or look on auction sites.
You should be aware that Practical Caravan Forum is principally aimed at touring caravanners, and whilst motorhomes often use a lot of caravan components and appliances, there can be some detail differences, which can complicate diagnosis and suggestions. You might find other owners and additional information if you were to also join the Practical Caravan's sister forum - Practical Motorhome forum.
Even if we knew the make, model and year of your motorhome I do not have any information about its wiring arrangements, so I can't define how the CAR/VAN switch operates and affects the use and charging of batteries. It needs a few minutes with a multimeter to check the way the system responds to switch positions.
What does concern me is that you have brought a series of different faults and symptoms to our attention. If this is indicative of the general condition of the motorhome, I am increasingly concerned about other potentially more serious safety issues which you may not have spotted. I urge you to have your motorhome properly checked for gas, electrical and water safety, sooner rather than later.
4,802
Ryan, I would like to thank yourself and the Prof,J. For your postings , I think this is the sort of help that the forum should give to the people that visit and join the site.
Hutch.
Nov 21, 2016
17
Hi John, I expect I will join pratical motorhome, as quite frankly, the information given by you has been amazing - hopefully they have an equivalent to you there! Seriously, you've really been a star, patiently and clearly explaining everything and offering your suggestions and opinions, all of which have been very helpful. I'm particularly impressed considering I'm on the caravan forum!
I will get the issues checked out, unfortunately I have neither the time nor money right now, and I'm in a foreign country so there are massive communication problems, and quite frankly the locals are rip-off merchants, and lazy incompetent ones at that. Hell, I took the van to one of the better reviewed and trustworthy garages round here to get an AT gearbox oil and filter change, plus a flush of the torque converter and a clean of the sump magnets, but when i got it back I found that they demanded 150 euros just to change the gearbox oil, and did nothing else! Not only that, but they didn't even supply the oil - I had already given them enough for 2 changes! So I'd probably end up broke or dead or both if I trusted the people round here to work on it. Even with my zero knowledge I would be better off doing it myself, with hammer, in the dark!!!! But I will get it checked out as soon as I am able to, and I do appreciate your concern.
I will try not to post anything more, I'm pretty sure I have all the answers I was originally looking for, and have been extremely happy with the help I've gotten here. If I have any further questions I'll try the motorhome forum, and if I ever buy a caravan I'll be back in a flash! I'm sure the information you've given me will help others with problems similar to mine, simply due to how clearly you presented it.
Thanks again! Ryan
EDIT: Thanks EH52ARH. Yeah this sort of information was invaluable to me. Hopefully it will also help the site, as judging from the amount of incomprehensible or false information I had to go to when I first started investigating the problem was ridiculous, so the information in this thread might help attract more users as older posts did for me.
When I found this site, and had seen the level of help being offered to people with caravans and mildly similar issues (I think some of the posts were from several years ago!) - that's when I signed up and made my first post as I knew I'd get decent information back if I structured my question well and didn't waffle (very hard for me) or go off on too many irrelevant tangents (also very difficult!). So hopefully this post adds nicely to that library and the site's userbase increases!
4,465
Hello Ryan
Please do keep posting, There are more similarities than differences between caravans motorhomes, and we should all be prepared to learn. In particular we would like to know what has been causing the pump problem, and the feedback of how we have helped or otherwise is interesting.
Ive not been trying to shut you down, it's more that I feel I've taken you about as far as we can without getting into some quite exotic procedures, and trying to suggest them and waiting for results becomes very tedious. Its the sort of things that a professional should instinctively know and complete in minutes.
There are those that don't like my long posts, but I find if the reason for a particular procedure is explained, then its more likely to be carried out correctly and to produce more reliable outcomes.
Best of luck, and dont be afraid to ask more questions. ;)
Nov 21, 2016
17
Yeah, there are a lot of similarities. I believe it was actually information on a cascade heater that you yourself had written that bought me here! Or possibly water pumps! I don't remember now! Basically, I have a caravan with a motor in it! :cheer:
At no point did I feel like I was being moved on, I think I had come to the same conclusion. I used to work in IT for a massive company and understand that eventually you will reach a point where you can no longer help without physically being in front of the machine or being able to talk to someone with enough experience to action what you're telling them and bring prompt and progressive steps forward.
Not only do I have that career which often required me to explain complex procedures to upper managers who probably thought their CD rom was a bagel maker, but now I teach people to ski and snowboard, so I completely understand why your replies are long and detailed - if the person you're explaining to can't come to the same conclusion on their own, your advice becomes pointless to them and you can't help them.
I would suggest that those that don't like your replies fit into one of three groups: Either they simply don't want to learn, are too stupid and reading and writing are a little too much for them, or they're already experienced in all this and what you're saying is just going over information they already know (in which case why are they posting?!?). I'm all for the detailed explanations - I read too many posts that simply had the answer in conlcusion, and 90% of the time that didn't actually help me understand the problem enough to help me fix it, and ascertain how much it might cost me to fix, or whether it is worth fixing, If I had an unlimited budget and could just give it to someone to fix I would have already done it, and thus wouldn't be on the forum, but thinking about it, a lot of people do ask stupid questions they haven't thought through, so perhaps people who give very short answers have just dealt with too many of those types of person! Who knows. Anyway, now I'm the one writing essays!
Nov 21, 2016
17
Oh, and as for the pump problem you will be waiting a while as I'm not planning on having a look until the spring! However, I'm a lurker by nature, so this is only really the second forum I'm a member of, so I won't forget you guys and I'll keep my problem details updated, although I may well be raising some topics from the dead by that point!!!!
Jun 2, 2017
141
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
brtgrh
