Carver Fanmaster Fire
Aug 24, 2007
139
My caravan (Swift Challenger 480SE) has a carver fanmaster fire and every trip I make I have to replace the control knob in the top of the housing. Has anybody else got this problem and if so have they managed to sort it so it doesnt pop out every time. Ken
Jun 17, 2011
826
27
It is spring loaded so that it pulls off when you remove the front. (It is the gas control I assume.) It attaches to a rod that goes to the gas valve. Might need a new one.
Feb 28, 2009
493
Hi Kenneth,
Yes this sometimes does happen.
The wire hoop on the end of the actuating rod can be opened up a bit to make the knob fit tighter or easier still a bit of Blue Tack in the hole normally holds it in place.
