Changing battery with solar panel
644
I need to replace our battery, and have one arriving today, question is, how do I turn off the solar panel, while I fit the new battery, or shall I do it at night?
D
Deleted member 23278
There should be an inline fuse in the positive feed from the panel to the controller, remove that. I've also done battery swaps by covering the panel with something opaque.
p.s. Remember to replace the fuse, I've rushed and forgotten!
644
So couldn't find a fuse as cables all run behind furniture, so decide to cover panel with carpet runner,changed battery but still problem with Reverse Polarity light flashing when I turn on mains battery charger, our AWS man has checked all the wiring and done the checks as suggested by Sargent and apart from the flash when switched on all is working fine and within spec, plan to live with it and see what happens. Special praise to Tayna batteries, ordered from website on Friday afternoon , battery delivered by Yodel Saturday lunchtime
9,607
Hope you never have cause to return the battery under warranty as Yodel and none of the normal courier companies will touch it. It’s classed “hazardous” and only a specialist licensed company can transport. I had a real fight with an online supplier based in north Wales. Told me to contact the manufacturer, in the end they sent me a new one and bent the rules by letting their delivery company collect the failed unit and had the nerve to charge £25 costs 🙁. Ever since then I’ve opted for local purchase.
3,901
Battery suppliers can use the same delivery companies to collect faulty batteries as they use to deliver new ones - the reason they don't is they're charged by weight and don't want to pay it for a faulty battery - the cost of original delivery is covered by the customer in the published price.
9,607
When I looked at companies to return the used battery none of the normal ones such as Hermes, Royal Mail, Hermes etc would accept it. I’ve posted several times wrt to my experience.
644
I would have preferred to use a local supplier for the battery for the resaons other Clive mentioned, but when I checked none was avilable in the spec I wanted, as is often the case nowadays, the local suppliers los eout to the internet, it happens to us in our business too,particularly when a supplier can cover the whole of the country from a unit in an area of low business rates etc. As far as possible return is concerned, we supply and deliver priducts that are classed as hazardous and our couriers don't have a problem, for what it's worth , when the battery arrived it was double bagged,and then packed inside a rigid cardboard box, within which it was wrapped, in thick paper, also had in transit plugs that had to be removed
9,607
My battery was packed the same and I’d retained the vent plugs etc but when it has been used it’s categorisation changes. Most used batteries go for recycling hence the need for licenced carriers or household recycling centres.
This link from another internet battery supplier summarises the situation. Fortunately not many have to return a battery under warranty.
5,505
Yep we had the same issue when a new battery packed up after only 3 months. We bought the replacement locally even though it cost an extra £10. Ii possible I will never buy a battery Online again
2,366
Bit of an aside to the purchasing question but relevant to the OP point:
Hadn’t thought of this until I read this post, but if you have a solar panel ( as we do) and want to remove the battery ( eg to charge at home in the winter), do you have to somehow disconnect the solar panel before removing or replacing the battery? And what happens if you don’t?
Reactions: Banus
5,505
On our caravan when you disconnect the battery, you disconnect the solar panel.
Reactions: Mel
644
Hi Mel
My thought was that the solar pane; would try to keep charging the battery even when old battery disconnected, I covered the panel and both the lights went out on the solar control box, changed the battery and uncovered the panel, all seems good.
Reactions: Mel
D
The screenshot below is from the 2018 Coachman manual (previous caravan) and it was true of the caravan before that - also Coachman - so it's become my 'standard procedure'.
The manual for the current caravan makes no mention of removing the solar-controller fuse but, I still do.
Reactions: Mel
2,366
Thank you all. Have no immediate plans to de-battery but will check out all the fuses next time we are in the van. Will also scour the usually unhelpful manual. Have never thought about it before. Every day is a school day.
2,366
Well guys, I duly scoured the marvellously comprehensive and totally thorough ( NOT) Swift owner manual, no mention of keeping the leisure battery connected when the solar panel is charging (but I am more inclined to the wisdom of Mickyjb’s screenshot) No mention of a fuse. No solar panel fuse listed on the Sargent electronics doodah under the front bench. However, did trawl the internet and found a picture of the Truma solar panel controller (which is what we have). There seems to be a blade fuse on the underside of the controller box. Assume this is the one I would need. Will check it is there when next in the van. Hope this helps someone else. We have a Sprite Alpine 2 btw.
Thanks again
644
Hi Mel
Don't know who writes the Swift handbooks, but like you I searched for info about solar and battery change, waste of time,we have alde heating so can't even use your Truma fuse idea, but mine is all done now, hopefully for a few years.
Reactions: Mel
5,505
Hi Mel
Same people that write the owners manuals for every other brand of caravan and car. They like to make it as clear as mud! LOL! :ROFLMAO: :ROFLMAO:
Reactions: Mel
D
Woodsieboy, The heating doesn't come into it, we also have Alde, it's the Truma solar controller (as shown below) with the blade fuse in the bottom (as fitted).
In our van it's in the cupboard below the solar panel.
Mick
Reactions: DaveA1
Aug 12, 2023
685
320
2,135
My charger (chinese noname) says connect battery first before solar panel. Disconnect solar panel (eg pull fuse) before disconnecting battery.
On your controller check that fuse is actually solar panel one, could be for battery. Ideally all 3 circuits should be fused ie solar in, battery, load out.
Aug 5, 2022
117
92
635
I was a bit surprised by a recent comment when having an annual service, including review of the electrical systems. My DIY solar install is 2x 175W panels, they are in series and commonly output about 40V. I used a double pole solar breaker in the cables near the roof, as per regs for a home install. Not a vast cost. Bloke said my install was “over the top”, he would have just hooked the Victron charger to the panels. Each to their own I guess, but personally I don’t want 40V at this available power in the caravan without a switch off option! The voltage would be quite capable of killing someone or causing fire in the wrong circumstances during servicing. Turning off our solar is easy.
Steve
18,515
Steve
I don't think 40 volts would kill you, anyway, remember the old saying "Volts jolts, mills kills". You can take a 10,000 volt shock that will give you a fair old belt, but not kill you, but a few milliamps will.
4,810
When I blew the end off of my pliers it was similar to a contact of a TIG welder, If I had a dodgy heart then that could have been a possibly deadly time. I am here just.
1,829
245
There really ought to be an an isolator switch between the solar controller and the battery, said switch should be fitted very close to the battery.
But, you most likely will not find an isolator switch as most caravan suppliers do things as cheaply as possible, even if their miserliness could lead to damaged equipment or damaged people.
Assuming that you most likely do not have an isolator switch or even an identifiable fuse to remove; just disconnect the plus signed cable (the positive - sometimes red coloured) from the solar controller, the positive cable entry point will be under a solar panel symbol.
Easy and safe way to isolate the solar panel from the controller and the battery at the same time.
