- Mar 14, 2005
- 1,633
- 623
- 19,935
I need to replace our battery, and have one arriving today, question is, how do I turn off the solar panel, while I fit the new battery, or shall I do it at night?
Hope you never have cause to return the battery under warranty as Yodel and none of the normal courier companies will touch it. It’s classed “hazardous” and only a specialist licensed company can transport. I had a real fight with an online supplier based in north Wales. Told me to contact the manufacturer, in the end they sent me a new one and bent the rules by letting their delivery company collect the failed unit and had the nerve to charge £25 costs 🙁. Ever since then I’ve opted for local purchase.So couldn't find a fuse as cables all run behind furniture, so decide to cover panel with carpet runner,changed battery but still problem with Reverse Polarity light flashing when I turn on mains battery charger, our AWS man has checked all the wiring and done the checks as suggested by Sargent and apart from the flash when switched on all is working fine and within spec, plan to live with it and see what happens. Special praise to Tayna batteries, ordered from website on Friday afternoon , battery delivered by Yodel Saturday lunchtime
Battery suppliers can use the same delivery companies to collect faulty batteries as they use to deliver new ones - the reason they don't is they're charged by weight and don't want to pay it for a faulty battery - the cost of original delivery is covered by the customer in the published price.Hope you never have cause to return the battery under warranty as Yodel and none of the normal courier companies will touch it. It’s classed “hazardous” and only a specialist licensed company can transport. I had a real fight with an online supplier based in north Wales. Told me to contact the manufacturer, in the end they sent me a new one and bent the rules by letting their delivery company collect the failed unit and had the nerve to charge £25 costs 🙁. Ever since then I’ve opted for local purchase.
When I looked at companies to return the used battery none of the normal ones such as Hermes, Royal Mail, Hermes etc would accept it. I’ve posted several times wrt to my experience.Battery suppliers can use the same delivery companies to collect faulty batteries as they use to deliver new ones - the reason they don't is they're charged by weight and don't want to pay it for a faulty battery - the cost of original delivery is covered by the customer in the published price.
My battery was packed the same and I’d retained the vent plugs etc but when it has been used it’s categorisation changes. Most used batteries go for recycling hence the need for licenced carriers or household recycling centres.I would have preferred to use a local supplier for the battery for the resaons other Clive mentioned, but when I checked none was avilable in the spec I wanted, as is often the case nowadays, the local suppliers los eout to the internet, it happens to us in our business too,particularly when a supplier can cover the whole of the country from a unit in an area of low business rates etc. As far as possible return is concerned, we supply and deliver priducts that are classed as hazardous and our couriers don't have a problem, for what it's worth , when the battery arrived it was double bagged,and then packed inside a rigid cardboard box, within which it was wrapped, in thick paper, also had in transit plugs that had to be removed
Yep we had the same issue when a new battery packed up after only 3 months. We bought the replacement locally even though it cost an extra £10. Ii possible I will never buy a battery Online againHope you never have cause to return the battery under warranty as Yodel and none of the normal courier companies will touch it. It’s classed “hazardous” and only a specialist licensed company can transport. I had a real fight with an online supplier based in north Wales. Told me to contact the manufacturer, in the end they sent me a new one and bent the rules by letting their delivery company collect the failed unit and had the nerve to charge £25 costs 🙁. Ever since then I’ve opted for local purchase.
On our caravan when you disconnect the battery, you disconnect the solar panel.Bit of an aside to the purchasing question but relevant to the OP point:
Hadn’t thought of this until I read this post, but if you have a solar panel ( as we do) and want to remove the battery ( eg to charge at home in the winter), do you have to somehow disconnect the solar panel before removing or replacing the battery? And what happens if you don’t?
Well guys, I duly scoured the marvellously comprehensive and totally thorough ( NOT) Swift owner manual, no mention of keeping the leisure battery connected when the solar panel is charging (but I am more inclined to the wisdom of Mickyjb’s screenshot) No mention of a fuse. No solar panel fuse listed on the Sargent electronics doodah under the front bench. However, did trawl the internet and found a picture of the Truma solar panel controller (which is what we have). There seems to be a blade fuse on the underside of the controller box. Assume this is the one I would need. Will check it is there when next in the van. Hope this helps someone else. We have a Sprite Alpine 2 btw.Thank you all. Have no immediate plans to de-battery but will check out all the fuses next time we are in the van. Will also scour the usually unhelpful manual. Have never thought about it before. Every day is a school day.
Same people that write the owners manuals for every other brand of caravan and car. They like to make it as clear as mud! LOL!Hi Mel
Don't know who writes the Swift handbooks, but like you I searched for info about solar and battery change, waste of time,we have alde heating so can't even use your Truma fuse idea, but mine is all done now, hopefully for a few years.
I don't think 40 volts would kill you, anyway, remember the old saying "Volts jolts, mills kills". You can take a 10,000 volt shock that will give you a fair old belt, but not kill you, but a few milliamps will.I was a bit surprised by a recent comment when having an annual service, including review of the electrical systems. My DIY solar install is 2x 175W panels, they are in series and commonly output about 40V. I used a double pole solar breaker in the cables near the roof, as per regs for a home install. Not a vast cost. Bloke said my install was “over the top”, he would have just hooked the Victron charger to the panels. Each to their own I guess, but personally I don’t want 40V at this available power in the caravan without a switch off option! The voltage would be quite capable of killing someone or causing fire in the wrong circumstances during servicing. Turning off our solar is easy.
Steve
