This is more a query than question
I will break it in to parts as to explain> I have working understanding of electronics and Electrics
1 Theory states you dont parallel charge batteries of different AH as the battery of lower AH will get charged but the bigger battery wont. So when charging leisure battery up in van via the 12s connection on car while driving does the leisure battery get charged properly as usually the car battery as about 45Ah and the leisure is about 85 or 110 Ah. so in theory the leisure battery would not be charged properly.
2 Ive noticed with some caravans the 3 way fridge is only powered from 12v then connected to the car and the vis the red wire pin 6 on the 12s socket and is not connected to the 12v of the caravan so if you did need to the 12v on the fridge while on site for what ever reason it wont work. But a simple change over relay would solve this if fitted in the caravan. But Ive never seen this
3 and finally Ive seen with some charging relay fitted to cars that come on via the ignition feed.ie when you ingition lights ar on on the dash you are powering your caravan up.If your car battery is a little low when starting it will try and pull current from the caravan battery and blow the fuses or worse burn out wiring if not fused.If lost count the times Ive had to hunt out the fuses and change them.So if your having electric fitted to your car.ASK them to show you where the fuses are for the split charge relays so if they do blow you know where they are
How many on here know where they are in their car.Are they under the bonnet,under the dash or in the boot.They could be any where
