Hi everyone. I'm new to this forum as just buying a caravan 🙂
Previously I've camped in a tent and have a 100Ah LiFEpo4 battery which has much more available power than a lead acid battery.
I initially wondered about using the lithium battery in a caravan however I understand that I cannot swap the Lead Acid leisure battery in the caravan for a lithium battery due to the different charging voltages etc.
So, I had an idea. Would it be possible to make up a cable that would utilise the car->caravan connector and provide power to the caravan from the Lithium battery? I expect i'll need a DC-DC converter to sure that the voltage is correct for the caravan.
Has anyone tried this or does a ready made solution exist? I'm thinking this will extend the 12v power considerably when off-grid.
Thanks,
Kevin
Thanks,
Kevin
