Charging of leisure batteries from the car
Sep 20, 2006
98
I have just bought a new van and i have been told that new vans are no longer charged by the car only by hook up not a lot of use if you want to use cl's dealer suggested solar panel on roof
We were not given a manual when we bought this van will be asking for one
Anybody else got any clues?
Geoff
geoff, the caravan battery can be charged by the car when the engine is running. The car battery feeds pin 4 of the 12S socket with the negative on on 3. On most vans there is a relay that is operated by the fridge supply on pin 6(+) and pin 7(-). The relay switches the supply on pins 4 & 3 to either provide power for the van 12v electrics when the engine isn't running or to charge the van battery when the engine is running.
Sep 20, 2006
98
Thanks John
I have looked at the Bailey service manual and it disagrees with what i have been told by Chichester Caravans so when i come back from my trip to Spain I will take the matter further
Thanks for the infomation
Geoff
Glad to be of help
If you want to use the fridge on 12V on the way to Spain make sure that the centre pin on the 12S socket has been connected to earth as this is the earth return for the fridge
The +ve feed is on the red wire at pin 6
Its not unusual for salesmen to give wrong information and when its done with authority its hard to dispute.
Sep 20, 2006
98
Fridge works fine on 12volt
Its just the charging to sort out its to late to worry now but will repost on forum when we return
thanks for all the comments
Walked outside today and winter has arrived
Feb 3, 2006
696
Geoff, make sure the fridge is set to battery when you travel and the battery switch set to "car".
