Checklist!!!
Jan 12, 2009
265
Good Morning Everyone
I remember a while ago there was a check list posted on the forum, for arrival onto site to check that you had done everything properly and hadn't forgotten anything.
Does anyone know where it is please, or does anyone know of a good checklist that they could recommend.
As it is our first trip away next week, myself and hubby are a bit nervous as to what we have to do. We know the basics, but also know that there is something very important that we will probably forget. The idea is to laminate a check list and keep it in the caravan.
Thank you
Sam
3,597
Sam
We have our own excel spread sheet modified over the years that covers everything for us.
Get Mr Mods to give me your e-mail and I'll send you a copy.
Cheers
Dustydog
Feb 26, 2007
512
Morning Sam,
If you go on to the following web site:-
www.oakwood-village.com
and scroll down to the title ......"Don't forget anything"
You will find lists which you can print off for virtually everything.
Mind you we have been caravanning now for 11 years and still forget things !!!!
Good luck
Maureen
Jun 16, 2008
74
Hi Sam
Here are the checklists I posted before. Hope you can adapt them to suit, as you will see we have a motor mover, so you will have to make some changes if you don't have one. At least it will give you a template to start with and then you can alter it to suit yourself.
LEAVING HOME
1. Connect to electric & switch fridge to mains to chill.
2. Flush water tanks with Milton (start of season only). Empty tanks if necessary.
3. Check everything stowed securely. All doors, rooflights & windows closed/clipped.
4. Switch fridge to 12 v setting & secure door etc. Control panel set to "Off".
5. LPG off and secure. Battery OK.
6. Mains cable disconnected from power first then caravan & then stowed.
7. Check all tyre pressures & wheel nuts (incl spare).
8. Remove wheel clamp & hitchlock. Switch on and wind on Motor Mover. Raise 4 corner steadies.
9. Handbrake fully released. Hitch up. Raise jockey wheel to highest & clamp. Attach breakaway cable & check stabiliser engaged. Connect 12 v cable & check all lights & mirrors ok.
10. Switch off and wind off Motor Mover. Stow towball cover & motor mover control.
11. Stow drill, levelling blocks, chocks & step. Lock door.
12. Check caravan level or slightly nose down. Car Level.
Stop after 20 miles to check all still ok, nothing moved, wheels cool, no cables trailing etc.
ARRIVAL ON SITE
1. Check in with site warden & reverse or drive onto pitch.
2. Disconnect breakaway cable & electrics. Unclamp & lower jockey wheel. Unhitch, disengage stabiliser. Apply handbrake.
3. Switch on and Wind on Motor Mover. Release handbrake. Move caravan into position.
4. Check levels with spirit level & adjust using ramps & jockey wheel. Move wheels till ok to fix wheel clamp. Apply handbrake. Lower corner steadies.
5. Switch off and wind off Motor Mover. Stow control safely.
6. Move car, put towball cover on, remove extending mirrors & check tyre pressures.
7. Connect mains cable to caravan first then to power.
8. Connect fresh & waste water containers. Fill and add chemicals to toilet tanks.
9. Control panel set to 'van'. Switch on pump. Purge water heater by running hot tap till running freely.
10. Connect/switch on LPG. Switch fridge to gas/mains. Switch on water heater gas/mains.
11. Apply hitchlock, wheel clamp and Hitch Head cover.
12. Assemble awning.
Put kettle on or open bottle of wine and relax.
LEAVING SITE
1. Awning down.
2. Disconnect water & waste hoses & empty tanks.
5. LPG off and secure. Battery OK. Control panel set to "Off".
6. Mains cable disconnected from power first then caravan and then stowed.
8. Remove wheel clamp & hitchlock. Switch on and wind on Motor Mover. Raise 4 corner steadies. Handbrake fully released.
9. Hitch up. Raise jockey wheel to highest & clamp. Attach breakaway cable & check stabiliser engaged.
10. Connect 12 v cable & check all lights & mirrors ok.
11. Switch off and wind off Motor Mover. Stow towball cover & motor mover control.
12. Stow drill, levelling blocks, chocks & step. Lock door. Check caravan level or slightly nose down. Car Level.
3,597
Claire Rob
Not an overkill at all.
We nearly went of last week without the glass turntable for the micro wave! Sad or what?
Seriously , I agree these lists are essential.
Cheers
Dustydog
