Club WiFi booster
Jan 18, 2025
Hi all.
Probably been asked many a time before…….
On our current site we use club WiFi. I have read numerous posts about using 3/4/5g sim mobile data receivers the likes of maxiveiw , avtex and alike. What I want to know is will these devices connect to the club WiFi on site (which requires a password) without having to use a sim? Problem I get is the signal inside the van is poor to none existent, so I require some type of signal booster to connect items inside the van to the WiFi. What’s out there and what have people used to overcome this issue?
Nov 30, 2022
1,693
1,532
2,935
A sim card gives access to the mobile phone network, WiFi is a totally different system and it doesn't require a sim card.
Jan 18, 2025
Cheers for reply. Well aware WiFi is different to using a sim on a mobile network. Was wondering if the systems available which use a sim over a mobile network will also work by picking up or designed to act as a WiFi booster using site WiFi.
Nov 30, 2022
1,693
1,532
2,935
That would be like trying to pick up a satellite TV programme with a terrestrial aerial, totally incompatible systems.
Jan 18, 2025
Not too different to what a mobile phone can do. It will pick up both sim and WiFi which you can hotspot from on other devices
Reactions: JTQ
2,940
Hi all.
Some MIFI units can be configured to pick up site WIFI and use it as input to the unit's local wifi, as well as picking up mobile phone broadband which needs a sim
Reactions: Chunky
2,315
11,935
With the massive improvement in mobile networks over recent years I have found that tethering to my phones hot spot rarely let me down. As a backup, we used two phones on different networks. After all. Data is so cheap now.
With weak signals, putting the phone in the skylight helped.
Reactions: Chunky and Dustydog
4,700
Like John we often use tethering when the TV signal is poor or no site WiFi.
I set up personal hotspot via settings on iPhone. This allows me to connect iPad (or smart Tv if you have one) to surf and stream programmes (provided mobile signal strong enough).
Data consumption is heavy but these days a lot of providers offer unlimited data.
Reactions: Chunky
Oct 19, 2023
537
415
1,135
On my last outing the mobile signal was excellent, the strongest signal I'd had on any site I'd stayed at. On the second day I checked my data usage and found that I'd used 12 gb, almost a quarter of my allowance (we'd watched 1 film and an hours catch-up TV). Normally I'd expect to use 3-4 gb for this. After doing some digging I discovered that my TV uses HD if the signal is strong enough, I had to downgrade the signal to SD on my Netflix account to stop this happening (couldn't figure out how to do it on the TV).
Something to keep an eye on if you're not on unlimited data.
2,940
I find mobile phone signal very variable - we're on Vodafone and Three and were surprised that the 3 sites we used on our southern England tour last year were very intermittent - worse than the Scottish Highlands where we expect the terrain to interfere with signals.
To overcome this , we've bought a TP-Link MR600 which is a MU-MIMO mifi to pull in a mobile signal and create a local wifi - we'll try it as it comes out of the box but may need to get an external pole antenna as the aerial height can be critical.
Reactions: Chunky
