Coat-hangers
Dec 14, 2006
79
18,585
Can anyone tell me if there are specially made coathangers that have some kind of locking device to keep them gripped onto the wardrobe rail? I have tried all manner of things to do this...the last being the most successful, a long strip of hook-and-eye tape, but even that fails under certain conditions!
6,260
Yes there are but quite expensive. You can get cheaper security hangars wire or wood or plastic. But then you can’t easily carry clothes on hangars to the van. I used cylindrical foam pipe lagging to keep wire hangars pushed together and then removed it when on site. Never had a hangar fall off.
Mar 17, 2020
490
364
4,935
Similarly as otherclive says but I've used a length of plumbing pipe cut along its length to clip over the rail and hangers.
It mostly worked but now I sometimes find the complete rail with hangers has jumped out. Hey Ho!
1,862
6,935
For some reason the current van is no problem though the wardrobs are always full.
A previous van. A Senator Arizona, was always a problem. we cured it in the end by stuffing scatter cushions between the rail and roof. That wardrobe was near the rear of the van which could have made things worse. Also, I dont think that that van had shock absorbers.
2,880
We used those round curtain rail hanger with a smaller loop. Hook the cloths hanger through the smaller loop. You have to take the wardrobe runner off and put the rings on and refit the runner.
Mar 17, 2020
490
364
4,935
That sounds to me like a great idea. Can you please add a link to the thingies!
I'm not sure what to search for.
6,260
If you search security coat hangars you will see many types available. Or book a night at a Premier Inn and take your screwdriver 😱
2,069
[/QUOTE
Sounds great we might give that a go (y)
3,425
32,935
We solved the problem by never carrying clothes on hangers as you are carrying weight high up. We lay the clothes flat on the bed.
1,792
If you have any wire ones I would bend the hook at the top until it is just bigger then the diameter of the rail. You can also do this with some cheaper hangers that have a thin metal hook.
Oct 3, 2013
890
90
18,935
Have you tried hanging the first coathanger one way then the next hanger the other way and so on.I'm told this works although I have no experience in this aspect of caravanning.
