Condensation in window
Can anyone advise best way to to remove and eliminate the condensation from a polyplastic double glazed window. I have one window which seems to suffer this complaint, there are no signs of any damage to the window.
Thanks in advance
Clive S
Clive, first of all it is worth remembering that caravan double glazed windows are not the same as your domestic units.
They are not hermetically sealed.
Ther are two small bungs in the inner window at the top, if you are very careful you can remove them to allow the moist air to escape, then replace them.
However, as the window material is, for want of a better word, breathable to some extent, it can never totally eliminate the problem, so it may recur at times.
What Damian says is true. They are porous to water vapour! On a day that is going to be warm take the bungs out, let the window clear, put bungs back in. In October it will probably be clouded again.
