Gafferbill's 10 tips on checking nose weight on single axle caravans.
The following will give inaccurate readings if not adhered to.
1: Clean caravan roof of bird excrement especially if the spread fore and aft of axle line is not even.
2: Make sure gutter above windows at front of caravan (if fitted) is dry and not full of debris.
3: Do not stand on A frame to take the readings.
4: Remember to detach the caravan from the tow car.
5: Readings must be taken whilst the caravan is on a level surface and stationary.
6: Handbrake must be off with both wheels chocked.
7: Hitch height during measurement must be the same as when attached to towing vehicle.
8: All steadies must be wound up and not touching the ground.
9: Do not take readings on days when wind speeds are above 20mph.
10: Remember to raise jockey wheel to obtain reading when using the acclaimed bathroom scales method.
Hope that helps
