Hi, My caravan is a dealer special "Abbey Expression 640" 2009 modle based on the Abbey Vogue 2. The switch on the control panel which switches on the caravan battery does not appear to be working as the indicator light does not come on and when I disconnect the electric hook up nothing works. When the electric hookup is connected and the battery charger switch is on everything works but only when the charger is switched on. The control panel is a printed circuit. The battery is brand new so I know there is no problem with that as the old battery was flat and after I recharged it it still did not work so I assumed it was dead as it is over 5 years old.
Another symptom was when I attempted to use the motor mover, the rollers moved onto the wheels but would not turn once there. As soon as I connected the electrics to the car it worked. As I say I am fairly sure the battery is Ok as it is brand new and showing fully charged.
I am assuming the problem is with the switch on the printed circuit but does anyone have any other ideas.
