- Dec 27, 2022
- 735
- 508
- 5,135
I have various bits of kit in the caravan that are controlled over bluetooth via apps on my phone. i.e. Battery charger, Solar charger, Li-on battery. The van is in storage 10 miles away so I can't just pop over and have a look.
Over the new year I decided that it would be good to check on these items remotely so I can ascertain how well the battery is charging in cold weather. As well as seeing how much battery is being used by alarm, tracker etc.
After much brain searching I came up with the idea of installing an old smartphone in the caravan and controlling it over 4g using TeamViewer as if I was actually there.
On the phone in the caravan I installed TeamViewer Host and universal add on. On my phone the main TeamViewer program.
This gives me full access to the remote phone as if I had it in front of me.
The only gremlin is you have to have physical access to the remote phone to aporove the first connection. After one connection you can connect/disconnect whenever you need remotely.
I happened to have an old phone and an old data SIM so it's been costless to set up.
At present the charger and battery are sitting in the workshop as I wanted to run a full test on it before install and it all works as expected.
Hope this idea may be of use to someone in the same situation.
