Hi all, the first trip in a new van (second hand Pegasus 462) was cut short because the hob gas rings would not stay alight. The hob is a Thetford series 170 with spark ignition. It lights instantly but even after holding the knob down for the time it takes to boil a kettle directly you release it the flame goes out. This is the same on all rings so I'm assuming it's not a thermocouple problem but the gas safety valve itself. Has any one had this problem and solved it without removing the hob? If not has anyone removed the hob from a Pegasus?
