Corner Steadies help
Apr 6, 2010
17
Hi
What is the correct procedure for setting up a caravan after unhitching from the car, I though it was leveling with the jockey wheel front to back, then lowering the corner steadies until I felt a little resistance, not using them to bear any real weight or to level the caravan, I also thought that I wasnt to adjust the jockey wheel once the steadies are down as this would then increase the pressure on the steadies and possibly splitting the floor.
My dad has advised me to use the steadies to relieve the pressure on the tyres, generaly applying 2.5 - 3 turns of the winding handle once I feel resistance, the caravan has now been placed in storage but my dad has lifted the jockey wheel into the stowed position after I pointed out that it had lifted from the ground after he had lowered the steadies, I tried questioning but he pointed out that he had more caravaning experience than me
I'm tempted to pop up tomorrow and adjust it and would appeciate some advice folks
Parksy
11,904
2,400
Hi Mary
You are absolutely right, the corner steadies are not jacks and your procedure for levelling the caravan is the correct one.
The tyres are designed to take the weight of the caravan and tyre side wall degradation is usually because of ultra violet light from daylight rather than 'pressure' from the caravan.
Some caravanners raise the jockey wheel after they have pitched their caravan but a modern caravan using an AlKo or Winterhoff chassis will be damaged it it is lifted by the steadies because the lightweight chassis will become warped.
Perhaps your father's experience relates to when caravans were solidly constructed on iron chassis rails, present day construction methods require different procedures.
Apr 6, 2010
17
Hi Mary
Hi Parksy
Thanks, Yes my Dad's experience is of old caravans, mine is a 1990 ABI Globestar but I think it does have an ALKO chassis, should I turn the handle until I feel resistance, will definately go up tmra and lower the jockey wheel and release the pressure on the steadies.
Parksy
11,904
2,400
That's right Mary, when you wind down the steadies and feel resistance and the caravan body lifts slightly the job is done.
On grass pitches you might need to re check after a couple of days when the ground is soft.
It's better to click on 'Reply to Topic' rather than 'Comment' when replying because your comments will not be so easy to notice.
I wish that the powers that be would get rid of the 'Comment' tab because it's useless.
Apr 28, 2009
40
I think another good tip when lowering corner steadies is to use a power tool with a torque control. Set it to it's lowest and then all 4 steadies will have even lightweight downward pressure.I even use the same setting on winding them back up.
40
If you use grass pitches more than hard, it's a good diea to spread the load under the steadies with suitable bits of wood, or, better the fiamma or other pads which attach to the bottom of the steadies and swing down automatically as you lower the steadies. these increase the contact area by a large margin and prevent you sinking in and having to adjust at frequent intervals. note that they are marked with an arrow which should point forwards so they will swing down correctly.
Some sloping sites may require wood blocks onder one or more of the steadies in addition to these pads.
Jul 3, 2010
hi mary
good advice to be had on here I think.
every one so far is correct or should I say if the van has an alko chasis it is correct. it clearly states on my vans paperwork ie; alko booklet that the van should not be jacked up via the corner steadies. it also recommends that the h/brake is applied to the fully vertical position when parked. however I never have because I believed it would stretch the cables and make the brakes seize if left for long periods.
I wondered if any of the members would care to comment on this.
Parksy
11,904
2,400
I always engage the handbrake before I unhitch the caravan from my car but if I'm on level ground I release the handbrake when the steadies are down. On sloping ground I leave the handbrake on to help to relieve the stresses on the caravan.
When my caravan is in storage I never lower the steadies or engage the handbrake. The caravan is stored on level hardstanding under cover so it's unlikely to be affected by the wind.
Apr 6, 2010
17
Hi
Thanks everyone for your comments, I had not really thought about what to do about the handbrake.
Will look into getting some of the pads to go on the ends of the steadies.
Cheers Mary
chenzhen
BANNED
May 19, 2016
99
"The word vintage, used to describe dresses and clothing, is a broad term that is generally used to refer to clothing that originates from a past era. In general, clothing that dates earlier than the 1920s, is considered to be antique. Whereas clothing and dresses that have emerged after the 1920s, up to the 1980s and 90s, is considered to be vintage. Retro, or vintage style, usually refers to clothing that is an imitation of the style of a previous era.
A range of vintage style clothing that is hugely popular today, are the fifties dresses. The enduring popularity of these dresses, might be because that was the time women's clothing made significant strides, as it was after the second World War and many restrictions had been lifted and designers had more freedom and materials available to create beautiful women's fashion ranges.
Some of the popular dress styles that have enjoyed a timeless appeal have included the Ophelia dress, floral tea dresses, Audrey Hepburn style dresses, the figure hugging Lindy Bop dresses and dresses made famous by Grace Kelly and many classic Hollywood stars. Even today, young women are choosing vintage style dresses for their special occasions such as a ball, prom night, and other formal parties, because they have a definite charm and elegance and have been designed to enhance a woman's shape and beauty."
fake oakleys
michael kors uk
cheap ray bans
rolex watches for sale
nike free flyknit 5.0
ugg boots
coach outlet online
yeezy boost 350 white
michael kors bags
air max 90 white
ralph lauren outlet
louis vuitton bags
converse sale
coach factory outlet
adidas shoes
nike free flyknit 3.0
burberry outlet
nike air force
cheap ray-ban sunglasses outlet
tory burch shoes
nike tn pas cher
chaussure louboutin
adidas nmd runner
louis vuitton handbags
skechers outlet
oakley sunglasses cheap
cheap jordan shoes
ray bans
adidas nmd black
reebok classic
adidas trainers
vans store
nike cortez white
pandora charms
air max 90
adidas shoes
fitflops shoes
timberland uk
pandora charms uk
armani exchange
burberry bags
under armour
louis vuitton outlet stores
oakley sunglasses wholesale
pandora jewelry outlet
cheap basketball shoes
ferragamo
ralph lauren
pandora rings
toms outlet
michael kors outlet online
prada sunglasses wholesale
cheap ray bans
www.coachfactory.com
cheap air jordans
michael kors handbags
valentino
michael kors outlet clearance
michael kors outlet
ugg boots
ralph lauren
ghd
mizuno running shoes
nike air force black
cheap jordans
nike free run flyknit
cheap ray bans
sac longchamp
kate spade outlet
cheap ray ban outlet
ray bans
true religion jeans
babyliss hair dryer
michael kors bags
true religion outlet
reebok outlet store
ray bans
nike trainers
polo outlet
fitflops
adidas superstars
true religion outlet store
kate spade uk
discount nike air max
ray ban sunglasses outlet
jordan pas cher
levis 511
nike huarache
omega speedmaster
christian louboutin uk
michael kors outlet store
tiffany jewelry outlet
polo ralph lauren men
adidas supercolor pink
rolex replica watches
ray ban outlet store online
cheap nike air max
coach outlet store online clearances
tory burch flats
hollister hoodies
nike cortez shoes
louis vuitton outlet online
hollister hoodies
pandora jewelry
louboutin outlet
coach factory outlet online
adidas pure boost black
designer handbags wholesale
yeezy boost 750
true religion
kate spade outlet online
tiffany uk
lebron james shoes 12
red bottoms outlet online
cheap jordan shoes
jordans
gucci borse
gucci handbags outlet
ray ban sunglasses sale
lacoste shoes
bottega veneta shoes
michale kors uk
ray ban sunglasses discount
louis vuitton uk
cheap ray ban sunglasses
longchamp outlet
micahel kors
adidas superstar white
air max
cheap nfl jerseys
burberry outlet
christian louboutin outlet
hollister clothing store
oakley sunglasses outlet
ralph lauren
nike blazer
michael kors canada
birkenstock sale
cheap ray bans
white converse
louboutin pas cher
jimmy choo
ed hardy uk
bottega veneta sale
north face outlet
nike air max 95
burberry sale
abercrombie and fitch outlet
hollister kids
louis vuitton purse
supra outlet
nike huarache black
nmd adidas
asics running shoes
lacoste polo shirts
jordan shoes
michael kors canada
abercrombie & fitch
coach outlet online
tiffany jewelry
burberry outlet canada
ray ban sunglass,ray ban sunglasses,ray ban outlet,cheap ray bans,cheap ray ban sunglasses,cheap ray bans,ray bans
ralph lauren outlet online
canada goose outlet
mlb jerseys wholesale
vans outlet store
birkenstock sale
coach purses on sale
ferragamo outlet
valentino bags
rolex submariner
mont blanc outlet
hollister co
nike air force
the north face outlet
armani outlet
tiffany and co outlet
michael kors handbgas
cheap oakleys
north face jackets
dior sunglasses 2016
coach outlet online
north face uk
kate spade bags
polo ralph lauren outlet
ray ban outlet online
adidas nmd uk
ghd hair dryer
jordan shoes
hollister uk
michael kors uk
buy red bottoms
nike roshe run
kate spade outlet
toms shoes
cheap oakleys
louis vuitton factory outlet
polo ralph lauren outlet online
puma outlet
true religion uk
chi flat iron
fitflops sale clearance
true religion jeans outlet
michael kors outlet canada
michael kors outlet
oakley sunglasses
instyler max
true religion jeans
fitflops
fitflops shoes
polo ralph lauren
pandora sale
michael kors outlet stores
hermes outlet
cheap oakley sunglasses
nhl jerseys wholesale
toms outlet
longchamp uk
timberland shoes
asics gel kayano
michael kors outlet
ed hardy
polo ralph lauren
versace sunglasses wholesale
louis vuitton borse
kate spade handbags
new balance shoes
versace sunglasses
birkenstock outlet
oakley sunglasses,oakley sunglass,cheap oakley sunglasses,oakley sunglasses cheap,oakley sunglasses outlet,oakley store,oakley outlet,oakley outlet store,oakley sunglasses sale,oakley sunglasses discount
michael kors bags
birkenstocks
nike air max 90
timberland boots for men
kobe bryant shoes
adidas shoes
birkenstock shoes
christian louboutin shoes
under armour outlet store
rolex daytona
michael kors outlet
abercrombie outlet
birkenstock uk
cartier
omega
polo ralph lauren
true religion sale
burberry outlet stores
nike shoes for cheap
nike store uk
sac longchamp pliage
nike force 1
ecco outlet
coach outlet online
louboutin shoes
canada goose jackets
nike free runs
reebok
converse outlet
coach outlet online
stephen curry basketball shoes
hollister kids
jimmy choo outlet store
nike air max 90
hermes belt
louboutin shoes
supra store
stan smith adidas
toms outlet
rolex watches uk
wholesale nike shoes
gucci outlet online
yeezy boost 350
nike free 5.0
cheap nfl jerseys
reebok shoes
coach outlet online
coach outlet store
tiffany and co jewelry
timberland shoes
ray ban outlet
timberland boots on sale
cartier love ring
white converse
louis vuitton purse
air max 90
ralph lauren pas cher
air jordan shoes
prada handbags
michael kors canada
holliste sale
adidas gazelle
nike flyknit racer
oakley sunglasses uk
yeezy boost 350 balck
lebron james shoes 2016
ralph lauren outlet
nike running shoes
kobe 11
nba jerseys wholesale
coach outlet store
michael kors handbags outlet
hollister clothing
louis vuitton pas cher
ralph lauren sale clearance
cheap oakley sunglasses outlet
"One of the most popular, but simple fifties dresses, is the petticoat. This was designed to be flattering to a lady's shape and also, to enhance the dress she was wearing over it. Petticoats made of silk and woollen materials were initially introduced for women to wear under the main dress, as they provided warmth and would enhance women's busts. The classic petticoat then became shorter and lacy petticoats became the fashion, as they delicately accentuated the dresses that were worn over them, such as the Ophelia dress.
Vintage style dresses UK are available in a wide variety of sizes from vintage clothing shops, textile fairs, auctions, flea markets, estate sales, antique markets, garage sales and collectable fairs. However, there is always the risk with buying genuine vintage clothing, that the sizes may not match current clothing sizes. But there are a number of special boutiques online, who specialise in designing and creating vintage clothing to order. They can take your specific measurements and produce an outfit that will be tailor made and fit you perfectly"
jgkidjhkljmnk
