Cost of caravanning equipment
584
I asked at a local dealer for the cost of two 240 volt three pin sockets and surface mounted boxes to match those in our caravan together with 6 plastic catches for the cupboards, as they had to be ordered specially from the caravan maker. The sockets were to match the existing ones and the catches were to keep in reserve in case of breakage.
They rang me today with a figure of................................£92.00 I decided not to proceed. I could change all of the 240volt sockets in the caravan for less than that and they would all then match. Has anybody any idea why the prices quoted for spares are so high?
Other than they charge those prices because they can. In the case of the sockets I have been unable to scource them elsewhere. Then SWMBO said why can't you take the one out of the cupboard and use that. Sure enough there was a matching socket in the cupboard for the microwave, so the happy ending was that we have an extra matching socket in the kitchen area and the microwave socket is now a white one courtesy of Wickes for less than a tenner, in the cupboard which doesn't show anyway.
Dec 11, 2009
632
Because it's got the word "caravan" in front of it.
936
Quote " so the happy ending was that we have an extra matching socket in the kitchen area and the microwave socket is now a white one courtesy of Wickes for less than a tenner, in the cupboard which doesn't show anyway."
Not so happy though !
Sockets in caravans must be double pole , the run of the mill domestic sockets from Wickes, B&Q etc are single pole
584
Hello Damien
I always use double pole in the caravan the one from Wickes is clearly marked double pole and was more expensive than the single pole one.
Don't wish to labour the point but here is a reply from Swift on another forum
Its the bottom line that makes my point
The loss of socket switches was a side effect of the move to a smaller format of switchgear (this was a few years ago), which was the subject of debate at the time of the change. The RCD is double pole and MCB's are single pole and switched neutral (i.e. they monitor over current in one pole but cut both poles in the event of actuation), and extensively tested at various stages of manufacture, of the component itself, the consumer unit it is installed into and as part of the electrical system of the completed caravan. It is important that this is re-inspected on a regular basis as per our guidleines to users. The combination of RCD, MCB and earthing arrangement provides protection against over current, short circuit and direct contact (by Human). The polarity should be checked before connecting as described in our handbook. The test button, when pressed provides an electrical path to earth, thereby causing the RCD to trip, this is to allow the user to carry out a simple test to ensure that the RCD operates, obviously if when the button is pressed nothing happens, the unit should not be connected to the supply. The switches found on earlier sockets were normally single pole
Andy
Sorry to disagree Damien but...
Sadly that wasn't the case in all the new vans we have had
All the sockets have been single pole switched in the Baileys but Swift get round it by fitting non switched sockets so a Wicks unswitched white one would be even cheaper and comply and they and B & Q do sell a range of double pole switched sockets that are still a lot less than coloured caravan ones
Its a good point and worth bearing it in mind to pay a few pence more for the double pole switched ones
ae235
http://www.screwfix.com/search.do?fh_search=double+pole+switched+sockets
http://www.diy.com/nav/fix/electrical/switches-sockets/white-switches-sockets/crabtree/Crabtree-13-Amp-1-Gang-Double-Pole-Switch-Socket-11567855
Mar 10, 2006
3,274
47
Yes double pole sockets are now freely available.
New caravans are supposed to comply to the latest iee regs 17th ed, but apparently NONE of them are.
Hi Like anything you buy from a caravan dealer Bailey, Swift ect you do pay thro the nose for that item, when we had our 2001 Bailey caravan the shower head need replacing, so off we go to buy one, got there and pick it up and WAIT!!! £98 they want for it, walk out drove to B+Q found one for £20 nice sliver one, better than the plastic one they had in the dealer showroom, Trevor123
584
I was under the impression that the double pole switched socket broke both sides of the circuit when switched off, from the reply from Swift it seems that they are relying on the RCD to protect the unswitched switches in their caravans. I would always prefer each socket to be individually switched.
The double pole switched socket does break both sides but they are not the norm in UK vans
I was amazed when I saw the first Swift unswitched sockets but alarm turned to conversion to the idea that it was better to unplug than to switch off the normal caravan pretty coloured sockets in the belief that they were double pole
In German vans the Schucko socket is unswitched
4,141
Hello Woodsieboy.
From your comment I think you may misunderstand then purpose of the switches on sockets and the RCD.
You are correct about the function of double pole switched breaking both L&N sides.
The removal of a plug or the use of any switch (if fitted) is to manually disconnect the supply to an appliance as and when the user wishes. They perform no automatic protection in the event of an appliance fault. Switches may be more convenient than having to remove a plug, but there is nothing as definitive as the physical removal of a plug to confirm disconnection.
Neither of the above does the same job as the RCD. The RCD continuously monitors the supply by comparing the current flowing in the live and neutral conductors, If every thing is normal both conductors will carry the same current. If a fault occurs in any part of the down-stream installation or appliances that allows any current to find an alternative route (usually to earth) that sets up an imbalance between the L & N conductors and when it reaches a pre-set threshold the RCD activates and disconnects the supply. In a caravan the RCD has to be a double pole device (as do the MCB's)
The RCD and MCB's provide the automatic safety whether or not the sockets are switched or not.
Hi John
I always think of the RCD like an old fashioned balance scale in that the live and neutral must be the same for the beam to be level and if one or other is different the trip trips
Are you sure that the MCBs are double pole because ours on the house are just replacements for the fuses which are in the live side only
Also on French sites we have found a reading on a proximity volt tester stick only to find that the reverse polarity of the site box was tripped out on the neutral MCB
I se that the devil is in the detail and you have stated caravan MCBs
They are indeed double pole in the Challenger as I just checked with my meter across the MCB contacts and both sides are broken (power off of course !!)
Thank you for the enlightenment
Mar 10, 2006
3,274
47
From what you posted either i took the CB to be double poled but only the live side to be "active" to trips, the neutral is only switched, but both act together.
unswitched sockets are a terrible cost cutting exercise, and should be avoided, pulling a plug that could be pulling 13 amps does no favours to the socket or plug contacts.
A double pole socket is the best, but price prohibitive.
Domestic installs don't require a double poled Cb as there is little chance of a reverse polarity, the only reason for them in a caravan, the double pole CB were fitted to my 2004 bailey, so there have been around for a while now.
4,141
Hello John,
No problem. I should add the DP MCB's were I believe a 16th edition requirement, prior to that I'm not sure.
Your RCD analogy with a balance scale is a good visual help, but don't forget that most caravan and domestic RCD's on the power ccts look for a 30mA discrepancy between L&N before tripping, anything less would probably result in nuisance tripping as every appliance will have some permissible electrical leakage as allowed for in PAT etc.
Hello Ray,
You are right, in UK domestic properties the chances of reversed supplies is very small, mainly because of the rigorous training and qualification process for electricians, and in the supply industry. and the fact the systems is generally connected just once and not subject to frequent reconnection's to different supply sources. This means that single pole over protection (fuses or MCB's) is an adequate form of over current protection.
However in situation like a caravan where the system is connected to many different and unknown supplies, a reverse phase supply may be connected especially when visiting the continent where revered phases are far more common in fact in some countries the phase is never tested so the likely hood of a reversed supply is about 50% Where this happens double pole isolation is the norm and the reason the testing is not needed.
If a single pole MCB system were on a reversed phase supply the incoming current will flow in the neutral conductor. If a N to E fault were to develop in the caravan then the L conductor would be starved of current and the over current protection may not trip.
Though this condition would be picked up by the RCD. The other danger would be that if a user turned off the MCB or removed the fuse, the appliance would still have components carrying the live potential inside.
Therefore double pole sensing and automatic isolation for overcurrent and current leakage is pretty essential where the polarity of the supply may not be known.
Aug 28, 2005
1,318
never mind your mcb or your rcd or your double pole , trevor 123 has got it right , every thing in the Caravan industry you pay through the nose for , i used to sell TV aerials which i could buy for £7.00 and you would pay £15 for in large DIY stores , and i have seen the same aerial in caravan accessory shops for £32
584
I was in Broad Lane Leisure at Alcester over the holiday and they had silver surface mounted boxes for sale, less than £4 each, still expensive for what they are, but we bought some and they are a perfect match to the ones in our caravan. Can only conclude it is the manufacturers driving up the retail price that the dealer becomes obliged to charge for spares,as the ones we bought were from the Powerpart range, and not a manufacturer part.
4,141
Its not just caravaning where spares and accesories are priced well above the manufacturing costs. It is a well known practice especially where a whole product is priced very keenly, the manufacture will put a much greater mark up on the cost of the individual parts.
Someone did a bit of working out many years ago, when a BMC Mini cost about £2K if you were build the car from manufactures spares the cost would be about £10K, and that was without the labour.
But it is certainly true that some types of product do attract very high mark ups, Caravanning is one but marine is even worse, and probably tops would be aviation.
Mar 21, 2007
443
18
18,685
We decided to fit net curtains in our new Lunar (have previously had them in our German vans and liked it) and could not find the appropriate runners other than buying from Lunar via a caravan dealer, and you can imagine how many we could have got from B@Q for the same price, if they sold them that is. There is an element of service here also with dealers holding specialised stock for a niche market and its not suprising they are not cheap. However the economics of small orders always lead to these prices, no matter what your hobby is if you want something that is not produced and sold in the millions you will have to pay for it.
chenzhen
BANNED
May 19, 2016
99
"The word vintage, used to describe dresses and clothing, is a broad term that is generally used to refer to clothing that originates from a past era. In general, clothing that dates earlier than the 1920s, is considered to be antique. Whereas clothing and dresses that have emerged after the 1920s, up to the 1980s and 90s, is considered to be vintage. Retro, or vintage style, usually refers to clothing that is an imitation of the style of a previous era.
A range of vintage style clothing that is hugely popular today, are the fifties dresses. The enduring popularity of these dresses, might be because that was the time women's clothing made significant strides, as it was after the second World War and many restrictions had been lifted and designers had more freedom and materials available to create beautiful women's fashion ranges.
Some of the popular dress styles that have enjoyed a timeless appeal have included the Ophelia dress, floral tea dresses, Audrey Hepburn style dresses, the figure hugging Lindy Bop dresses and dresses made famous by Grace Kelly and many classic Hollywood stars. Even today, young women are choosing vintage style dresses for their special occasions such as a ball, prom night, and other formal parties, because they have a definite charm and elegance and have been designed to enhance a woman's shape and beauty."
fake oakleys
michael kors uk
cheap ray bans
rolex watches for sale
nike free flyknit 5.0
ugg boots
coach outlet online
yeezy boost 350 white
michael kors bags
air max 90 white
ralph lauren outlet
louis vuitton bags
converse sale
coach factory outlet
adidas shoes
nike free flyknit 3.0
burberry outlet
nike air force
cheap ray-ban sunglasses outlet
tory burch shoes
nike tn pas cher
chaussure louboutin
adidas nmd runner
louis vuitton handbags
skechers outlet
oakley sunglasses cheap
cheap jordan shoes
ray bans
adidas nmd black
reebok classic
adidas trainers
vans store
nike cortez white
pandora charms
air max 90
adidas shoes
fitflops shoes
timberland uk
pandora charms uk
armani exchange
burberry bags
under armour
louis vuitton outlet stores
oakley sunglasses wholesale
pandora jewelry outlet
cheap basketball shoes
ferragamo
ralph lauren
pandora rings
toms outlet
michael kors outlet online
prada sunglasses wholesale
cheap ray bans
www.coachfactory.com
cheap air jordans
michael kors handbags
valentino
michael kors outlet clearance
michael kors outlet
ugg boots
ralph lauren
ghd
mizuno running shoes
nike air force black
cheap jordans
nike free run flyknit
cheap ray bans
sac longchamp
kate spade outlet
cheap ray ban outlet
ray bans
true religion jeans
babyliss hair dryer
michael kors bags
true religion outlet
reebok outlet store
ray bans
nike trainers
polo outlet
fitflops
adidas superstars
true religion outlet store
kate spade uk
discount nike air max
ray ban sunglasses outlet
jordan pas cher
levis 511
nike huarache
omega speedmaster
christian louboutin uk
michael kors outlet store
tiffany jewelry outlet
polo ralph lauren men
adidas supercolor pink
rolex replica watches
ray ban outlet store online
cheap nike air max
coach outlet store online clearances
tory burch flats
hollister hoodies
nike cortez shoes
louis vuitton outlet online
hollister hoodies
pandora jewelry
louboutin outlet
coach factory outlet online
adidas pure boost black
designer handbags wholesale
yeezy boost 750
true religion
kate spade outlet online
tiffany uk
lebron james shoes 12
red bottoms outlet online
cheap jordan shoes
jordans
gucci borse
gucci handbags outlet
ray ban sunglasses sale
lacoste shoes
bottega veneta shoes
michale kors uk
ray ban sunglasses discount
louis vuitton uk
cheap ray ban sunglasses
longchamp outlet
micahel kors
adidas superstar white
air max
cheap nfl jerseys
burberry outlet
christian louboutin outlet
hollister clothing store
oakley sunglasses outlet
ralph lauren
nike blazer
michael kors canada
birkenstock sale
cheap ray bans
white converse
louboutin pas cher
jimmy choo
ed hardy uk
bottega veneta sale
north face outlet
nike air max 95
burberry sale
abercrombie and fitch outlet
hollister kids
louis vuitton purse
supra outlet
nike huarache black
nmd adidas
asics running shoes
lacoste polo shirts
jordan shoes
michael kors canada
abercrombie & fitch
coach outlet online
tiffany jewelry
burberry outlet canada
ray ban sunglass,ray ban sunglasses,ray ban outlet,cheap ray bans,cheap ray ban sunglasses,cheap ray bans,ray bans
ralph lauren outlet online
canada goose outlet
mlb jerseys wholesale
vans outlet store
birkenstock sale
coach purses on sale
ferragamo outlet
valentino bags
rolex submariner
mont blanc outlet
hollister co
nike air force
the north face outlet
armani outlet
tiffany and co outlet
michael kors handbgas
cheap oakleys
north face jackets
dior sunglasses 2016
coach outlet online
north face uk
kate spade bags
polo ralph lauren outlet
ray ban outlet online
adidas nmd uk
ghd hair dryer
jordan shoes
hollister uk
michael kors uk
buy red bottoms
nike roshe run
kate spade outlet
toms shoes
cheap oakleys
louis vuitton factory outlet
polo ralph lauren outlet online
puma outlet
true religion uk
chi flat iron
fitflops sale clearance
true religion jeans outlet
michael kors outlet canada
michael kors outlet
oakley sunglasses
instyler max
true religion jeans
fitflops
fitflops shoes
polo ralph lauren
pandora sale
michael kors outlet stores
hermes outlet
cheap oakley sunglasses
nhl jerseys wholesale
toms outlet
longchamp uk
timberland shoes
asics gel kayano
michael kors outlet
ed hardy
polo ralph lauren
versace sunglasses wholesale
louis vuitton borse
kate spade handbags
new balance shoes
versace sunglasses
birkenstock outlet
oakley sunglasses,oakley sunglass,cheap oakley sunglasses,oakley sunglasses cheap,oakley sunglasses outlet,oakley store,oakley outlet,oakley outlet store,oakley sunglasses sale,oakley sunglasses discount
michael kors bags
birkenstocks
nike air max 90
timberland boots for men
kobe bryant shoes
adidas shoes
birkenstock shoes
christian louboutin shoes
under armour outlet store
rolex daytona
michael kors outlet
abercrombie outlet
birkenstock uk
cartier
omega
polo ralph lauren
true religion sale
burberry outlet stores
nike shoes for cheap
nike store uk
sac longchamp pliage
nike force 1
ecco outlet
coach outlet online
louboutin shoes
canada goose jackets
nike free runs
reebok
converse outlet
coach outlet online
stephen curry basketball shoes
hollister kids
jimmy choo outlet store
nike air max 90
hermes belt
louboutin shoes
supra store
stan smith adidas
toms outlet
rolex watches uk
wholesale nike shoes
gucci outlet online
yeezy boost 350
nike free 5.0
cheap nfl jerseys
reebok shoes
coach outlet online
coach outlet store
tiffany and co jewelry
timberland shoes
ray ban outlet
timberland boots on sale
cartier love ring
white converse
louis vuitton purse
air max 90
ralph lauren pas cher
air jordan shoes
prada handbags
michael kors canada
holliste sale
adidas gazelle
nike flyknit racer
oakley sunglasses uk
yeezy boost 350 balck
lebron james shoes 2016
ralph lauren outlet
nike running shoes
kobe 11
nba jerseys wholesale
coach outlet store
michael kors handbags outlet
hollister clothing
louis vuitton pas cher
ralph lauren sale clearance
cheap oakley sunglasses outlet
"One of the most popular, but simple fifties dresses, is the petticoat. This was designed to be flattering to a lady's shape and also, to enhance the dress she was wearing over it. Petticoats made of silk and woollen materials were initially introduced for women to wear under the main dress, as they provided warmth and would enhance women's busts. The classic petticoat then became shorter and lacy petticoats became the fashion, as they delicately accentuated the dresses that were worn over them, such as the Ophelia dress.
Vintage style dresses UK are available in a wide variety of sizes from vintage clothing shops, textile fairs, auctions, flea markets, estate sales, antique markets, garage sales and collectable fairs. However, there is always the risk with buying genuine vintage clothing, that the sizes may not match current clothing sizes. But there are a number of special boutiques online, who specialise in designing and creating vintage clothing to order. They can take your specific measurements and produce an outfit that will be tailor made and fit you perfectly"
EEWQE
