I have a possible claim under the act, what do others think?
My MG ZS has performed as expected for the most part. The lights were a problem in that: On startup they all came on in bright sunshine, including fog lights. The dealer said they could not recreate the problem. I needed to get the technician to stand in front of it while I started it. Then I said, “What lights do you see?”. Then, “What should you see?
Unbelievable.
They changed the daylight sensor, So fixed. But:
Now, at night, I get fog lights! After discussion and trial and error it was discovered that the fog light should come on, but only when the steering is turned to a certain angle. This is to aid cornering. On test, they seemed to work, but later they were found to remain on intermittently when the steering was straight.
I am not too bothered about this, I think it will be fixed eventually. Half the problem is getting the dealer to accept something is wrong.
Now my main issue. The cruise control (not the radar type). Is supposed to operate in the same manner as every other car I have driven. And it does, until is comes to clicking down on speed. With the cruise set, each click down should reduce the speed by 1mph. (Some cars use 5mph).
With this car, it will stop operating at certain speeds, 22, 27, 32, 37, 42, 47 etc. So, if I am traveling at 54mph and feel I am catching up with the traffic, I may click 4 times and expect the new set speed to be 50mph. But no, I get 52mph. Infuriating, and possibly a bit dangerous.
The dealer, and MG, have told me,
Thats normal.
They are all like that.
Other makes do that.
It's the way I use it.
They are still insisting that there is not a fault. But the case has been raised and gone back to China. Who were not aware, aparently I must be the only owner world wide to have discovered this issue. They admit it does this and that it MAY be fixed in a future software update. But there are no plans to do so.
So, there is no fault, but they may fix it in the future???
So, the balls in my court. Should I rase a case. I have already sent them a recorded letter of intent.
Unbelievable.
Thats normal.
