Crystal 2 compact inlet to Ultraflow
Hi all. The old Crystal 2 water inlet on my Adria leaks like hell - I suspect the housing is cracked somewhere. I want to replace it with a new Truma Ultraflow inlet but use a Whale Watermaster submersible pump and hose with the Ultraflow compatible connector. The existing Crystal 2 inlet is the compact style, i.e. without a filter Is the Truma Ultraflow compact inlet a straight swap, i.e. it fits in the same cutout in the van wall? And will the Whale pump fit OK in the compact Truma Ultraflow inlet? Thanks in anticipation.
Hi Waysideken,
Yes, the Whale Watermaster (EP1642) is designed to fit the Truma Ultraflow inlet, it’s a plug and go fitment.
Kind regards,
Rachel
Have also had confirmation from Truma technical advice line that their Ultraflow inlet should be a straight swap for the old Crystal one. Sorted! 🙂
