- Mar 14, 2005
- 127
- 0
- 0
Morning all - I know that there have been several threads on this topic over the last few months so I hope I am not boring everyone if I raise it again!
1. When applying the meter probes to the surface of the internal lining panel does it really indicate the dampness of the structure underneath?
2. I have been told that a small area of the outer wall in the shower compartment gives a reading of 25% and that it should be re-checked after 3 months. My own B&Q meter also indicates moisture. Note that it is several weeks since we used the shower and then only on 2 or 3 occasions.
3. So the question arises as to how accurately that surface measurement reflects the true moisture within the wall?
4. Presumably the dealer is expecting the moisture to evaporate through the inner lining (it certainly won't evaporate through the outer aluminium sheet).
5. Does anyone have thoughts on this matter? How much timber is there in the outer wall of a 1998 Abbey? Is timber only used around the window and door openings, and presumably at the panel edges, or is there some elsewhere in the body of the construction?
6. Is it possible to speed up the drying out process in any way?
7. Over to you!
7. Over to you!
