- Nov 11, 2009
- 25,923
- 9,579
- 50,935
I contacted Nextbase and surprisingly they still have no suction fittings available and are even stock out on adhesive mounts. So it’s a case of self help again. But looking at the 522gw installation instructions I feel they contribute to the problem. After cleaning the screen you are instructed to hold the new adhesive pad against the screen for 5 seconds. This seems a very short time as most other types of adhesive pad bonds state 30 seconds, and then leave for a period of time unloaded to allow curing. Yet for Nextbase straight after attaching the pad you install the mount and then camera. You are then advised to align the camera for view and adjust its polarising filter. Then if the kit has been fitted by a technician they will no doubt demonstrate to you how to remove the camera, or adjust settings etc. If it’s not fitted at home then there will be road perturbations on the mounted dash cam.
So I’ve obtained some 3M VHB pads and today I will reinstall it by pressing the pad to windscreen for 30 seconds and then leaving the adhesive to cure for 24 hours before reattaching the camera etc. Then do the same again in October😱
