- Apr 14, 2006
- 20
- 0
- 0
Hi all,
I've just discovered the floor of our Avondale Dart is delaminated, just infront of the sink, it's effected about a 3-4ft square. Initially I thought OMG this is going to cost alot, a dealer quoted 200-300quid. Having looked into it, it don't seem to be as bad as I first thought. Basically, I'd like to hear from others out there who have had the same problem and have fix this themselves. If y ou can give any advice it would be great.
My plan is to drill 6mm holes, about 6" apart, pump in a resin and plug up the holes with 6mm dowl's and put a weight on top while drying.
We have a vinyl floor and will need to pull it up. Can a new replacement carpet be used and if so, are they bought pre-cut or how do I basically fit a new carpert, do you have to use a "Caravan Carpet".
