- Jul 18, 2017
- 15,945
- 5,019
- 50,935
In the past every couple of months I have added Miller diesel engine cleaner which is supposed to clean the fuel system and injectors, but I have not done so recently. By adding the additive to me it seemed as if the vehicle was running quieter. I am not sure if it improved economy.
Recently the car has very occasionally experienced a "flat" spot while travelling almost as if the car is coasting and car slows down until I give the accelerator a gentle touch. The issue disappeared after a long tow, but may have occurred again yesterday.
Taking into consideration over the past two years the car the car has only done 14000 miles and less than 7000 miles in the past year. Many journeys have been maximum of 14 miles on A roads where speed kept to about 50mph. I am now wondering if perhaps the DPF is not getting the opportunity to regenerate properly or due to low mileage the injectors or perhaps fuel line needs cleaning? I am guessing. The car is 10 years old with 73K on the clock.
At the moment the tank is about third full. Choice is paying the extra for a tank full of Supreme or buying an additive to run through and hopefully clean the system. The difference in cost for the Supreme or buying the bottle of additive cleaner is almost the same however250ml of the additive is only good for 60 litres and my tank is a lot bigger so the additive costs more.
I used to buy Millers from Halfords, but they no longer stock so thinking of either Forte or STP DPF regenerator additive and also an engine cleaner. Maybe use them plus the Supreme fuel. Any thoughts?
