Do I need a new 12 volt battery ? Which one ?
Jul 19, 2021
608
417
5,135
that Powermaster should be an all in one charger/distribution thingy. Sounds like the charger has given up and replaced with an after market unit.
If it is a trickle charger it may not be charging the battery enough when you are running lights etc. Other issue can be overcharging a battery which will reduce its lifespan
Reactions: Tommyscaravan
Jun 27, 2021
52
21
85
I think you’re right , looks that way !
4,939
Yes I am regarding the battery however the battery comes in a carry box as it was used for going off grid. It looks very similar to this. If you are happy to pay £20 for the box, the battery is free.
Remember that the battery may be okay for a couple of years or it could go kaput next week which is why I cannot sell it. It is unlikely though to give up the ghost.
I have not charged it for 3 weeks, but will check the voltage later this morning and let you know. We will be going through Powick at about 1045 hours this morning and again tomorrow.
Jun 27, 2021
52
21
85
Ok thank you , I understand re the battery “lasting”luckily I measured the space th have for the battery… although I didn’t measure the height of it as I didn’t think that would be an issue , does the battery box come off . Does battery come out of box ? The space I have for battery is about 15cm deep and 35 wide . If battery will fit based on those dims I would happily buy it ?? Should I measure again and come back to you ?
4,939
The battery is inside the box and can be removed easily. It was a backup battery for when we went off grid which was only a about twice in a few years. Here is the specification the battery;
Numax CXV31MF Sealed Leisure Battery 12V 110Ah 1000MCA 500 Cycles XV31MF
The battery box is Numax Deluxe Battery Box.
