I wondered if a water check valve is needed. is it usually supplied by the manufacturer? Is it better to install it closer to the pump or closer to the tap? or next to every tap?
Normally a non return valve in the water inlet supply but check valves like domestic house supplies aren’t used in caravans. Your water comes from the mains via aquaroll or via a serviced pitch supply direct or via aquaroll.I wondered if a water check valve is needed. is it usually supplied by the manufacturer? Is it better to install it closer to the pump or closer to the tap? or next to every tap?
Water comes from an external tank.Normally a non return valve in the water inlet supply but check valves like domestic house supplies aren’t used in caravans. Your water comes from the mains via aquaroll or via a serviced pitch supply direct or via aquaroll.
What’s the outfit configuration that you have? Are you referring to the Aquaroll?Water comes from an external tank.
Yes AquarollWhat’s the outfit configuration that you have? Are you referring to the Aquaroll?
Well why would you need a check valve? You sterilise the aquaroll and connector pipe periodically. You fill from mains quality water supply and the aquaroll is food quality plastic with a rubber cover. So it’s not like a domestic system with a garden hose take off or water softener etc to potentially introduce contamination.Yes Aquaroll
I thought about the valve because the water is leaving the tap. Each time you need to wait a while again so that it flows again after opening the tap.Well why would you need a check valve? You sterilise the aquaroll and connector pipe periodically. You fill from mains quality water supply and the aquaroll is food quality plastic with a rubber cover. So it’s not like a domestic system with a garden hose take off or water softener etc to potentially introduce contamination.
