do i need a water check valve?
Jul 9, 2021
93
23
1,585
I wondered if a water check valve is needed. is it usually supplied by the manufacturer? Is it better to install it closer to the pump or closer to the tap? or next to every tap?
9,474
Normally a non return valve in the water inlet supply but check valves like domestic house supplies aren’t used in caravans. Your water comes from the mains via aquaroll or via a serviced pitch supply direct or via aquaroll.
Jul 9, 2021
93
23
1,585
Water comes from an external tank.
9,474
Yes Aquaroll
Well why would you need a check valve? You sterilise the aquaroll and connector pipe periodically. You fill from mains quality water supply and the aquaroll is food quality plastic with a rubber cover. So it’s not like a domestic system with a garden hose take off or water softener etc to potentially introduce contamination.
Jul 9, 2021
93
23
1,585
I thought about the valve because the water is leaving the tap. Each time you need to wait a while again so that it flows again after opening the tap.
