I have a 6KG full propane cylinder. When I connect the pigtail to it and open the valve, I can hear gas leaving out at the join to the cylinder. I have tried connecting it many times and tightening it up more but it is still leaking. Weird thing is, if I screw in the black plastic safety cap and then open the valve, I cannot hear any leaking.
The other cylinder in the van works fine - I have connected that one for now - no leaks and no noises, nor with the prior one I had which was just replaced with a refill.
The local caravan shop is reluctant to swap it out for free as they said “Calor are a nightmare and already owe us about 2 grand”. They gave me a phone number at Calor to call.
Does Calor actually have a working process to deal with this which I can go through as I need 2 cylinders for some trips in July and I’ll be forced to simply swap out the full one and pay for the gas twice if not.
I assume it’s not ok to dissipate the gas into the open air slowly over some days so the canister is empty and then swap it - frankly I am not sure I want it hanging around near my caravan and car while it’s still full, although it does not appear to be leaking when the valve is fully closed.
