The Dometic fridge in our Senator Oklhoma S5 works (like just about every other caravan fridge) on either gas, 12v or 230v. However, until now I had not realised that to run on 230v you actually need 12v also (or at least, you need the 12v leisure battery to be fitted).
We are on site in Germany (30+ degs!) and last week we found the 12v battery to be totally flat. I checked all the relevant fuses and circuit breakers all OK. Hmm, battery is only a year a so old but could be that a cell has gone. Found a local auto shop and asked them if they could check the battery, which they willingly did, to announce that it was so flat they could not check it properly, so they put it on charge for the rest of the day. In the meantime we discovered that fridge had stopped working on 230v (this on a day of temp well over 30 deg). Checked fuse etc, no problem, definitely 230v available to the fridge. Read the fridge manual, ditto the Senator one, no mention that a 12v battery had to be in circuit for the fridge to work on 230v. Rang the Bailey dealer and spoke with the workshop manager and yes, daft though it sounds, the 12v battery needs to be in circuit for the fridge to work on 230v.
Is this a quirk of the way the fridge is installed in the Senator or does it apply to all Dometic fridges?
