Is that a modern thing? The Electrolux/Dometic fridge in our 2001 Bailey Pageant could be run on any or all sources - I used to leave the switches set for 12v and mains electric because they were never both plugged in together - but I don't recall anything stopping the gas being used as well.It's not possible to run off gas AND electricity at the same time, is either or, not both.
Thanks for the info been reading since 5 this morningIf you have ice in the top part then it's clearly working as it should. If youbave very little in the main part then it's simply full of air, as soonas yiu open the door that cool air will drop out of tge bottom to be replaced by air at the ambient femperature. So try and keep opening yiur fridgea minimum amount for as short a time as possible.
A fan to draw out tge warm air from the back of the fridge can have a pretty dramatic effect when the ambient temperature is mid 20's and above. A quick search for fridge fan will give yiu plenty of reading material.
No awing up to much bother on me own no vent holes round fridgeDoes the fridge vent into the awning? Previously when in France we used a small fan on the bottom vent and it seemed to resolve the issue.
I tried 230 first hours then over to gas I'm freezing some ice blocks to put in main control I reckon the new van fridges aren't up to the job wasn't broken didn't need fixing a nother step back modern tecCaravan fridges normally use the Absorption process to cool the fridge. The fact you mention using Gas and Electricity tells me your fridge is one of these. They have a limited ability to cool so when ambient temperatures are high, these fridges can struggle. Check the specification of your fridge for its maximum ambient temperature.
When you tell us "main part still warm running on gas and electric " Do you mean you are using both gas & electricity do you mean your using both power sources at the same time? If you are, you may be adding extra heat to the back of the fridge, and that might be compromising its performance. Try with just one fuel source at a time... Sometimes more (heat) isn't always going to mean better cooling.
As has been mentioned in other answers, some people who regularly caravan in high temperatures fit fans to the fridges exterior vents to increase air flow through the condenser panel at the back of the fridge.
+1 remove the vent covers on our caravan when in use 👍Decades ago my Electrolux RM 212 was one or other not both as have all the successors to date.
Like Hutch I never got round to fitting the fans, still on board!
But we always remove the external vent covers when in use
You may know this but for the benefit of others the winter/travel covers should be removed if the ambient temperature is over 7-10 degrees Celcius - it may be beneficial to remove the complete vent in hot weather if the fridge isn't coping well.Gents, when you say you remove the vent covers, do you mean, Winter/ Travelling covers or do you mean the complete louvred vents.
.....helps the caravan fridge in hot weather if you remove any gauze fly screens that are often fitted behind the louvre vents.
They effectively reduce the area of the aperture by more than you might think and slow down airflow.
They just pull away, the insect screens are quite flexible, normally 4 or 6 small little bumps that the screens fit under.Do they just pull off easily? Or are tools/technique involved?
