I recieved an airmail letter this morning from Dometic in Germany.There is a problem with the cooling unit,seemingly some of the screws that are used to fix the unit on the housing are of inferior quality and may loosen due to vibrations,the fridge/freezer is still usable but not on gas and must be isolated by the gas shut off valve.
The offending serial numbers are 401xxxxx to 734xxxxx these numbers are on the inside of the fridge door. If you have one of these fridges you must contact your supplying dealer.
