Dometric fridge beeping
Jan 21, 2018
11
Hi guys
We have just bought a new swift challenger and every time we go away the alarm on the fridge keeps beeping. Can anyone advise what to do please.
Jun 24, 2005
704
Hi,
Our's beeps is the mains voltage drops too low or the fridge door is not shut properly - sometimes it needs a good shove to stop it. As it's a new 'van I'd suggest taking it to the dealer for his comments.
Feb 23, 2018
923
90
18,935
Ours beeps if left open too long (intentionally) and when disconnected from the mains. If it is beeping when connected to the car and the engine is running, your car's electrics might not be wired to supply 12v to the fridge.
Sep 29, 2016
1,829
245
Damian-Moderator said:
Have you read the operating manual for your fridge???
Good point, the trouble shooting section of the fridge manual would likely cover that problem issue.
1,819
Ours beeps if it is switched on but there is no power from whatever it is set to use. Most noticeable when traveling and you switch to battery before you set off but the car is not yet providing power. It should be a warning that something is wrong.
5,253
We had this issue in our previous caravan and there was an issue with the door catch which needed replacing.
Jun 12, 2018
We have just purchased a bailey unicorn Cordoba,, with the same annoying problem , however playing about. With the door contact a.onthe led side... pressing it in and out a few time seams to have worked...for now anyway..we have also been applying Extra hand pressure where the door locks..as to seal the magnet,s a bit more.4 Hours gone by and no bleeping as yit.
