Done a Very stupid Thing
Jul 12, 2016
Just purchased a caravan and used a power washer to clean. i was not very close but i did use one. now i have read this is very bad. will all the seals now be damaged.
its a 2005 caravan
Apr 20, 2009
5,642
1,053
:( :( :( :( :( Oh Dear,
On a serious note have you checked inside the van for any immediate signs of water ingress?
Check all the seals outside to see if there is any evidence of the power washer disturbing them.
On a happier note, I suspect you may well get away with it if its just the once. As long as you were not too close.
Have you a damp meter, if so you can keep an eye on the damp readings over the next couple of months.
Mar 13, 2007
1,750
hi, I went up to the local-ish caravan dealers last week to get a new 7 to 13pin converter [lost mine] while there noticed one of the dealers staff washing their caravans, with a jet wash, so it's not all bad news,
4,738
Welcome, and dont worry to much. I use a pressure washer on mine, but gently. .
Nov 12, 2013
2,955
Welcome to the forum, tedglen2 and congratulations on the purchase. Fingers crossed not too much damage is done and you've got away with it.
1,819
It might be bad news if you buy one from them although it may be they used a lower power setting.
Mar 31, 2011
55
Hi, just checkout YouTube for how to clean a caravan (without the use of a hose pipe.) power washing Is'nt recomended as it can be very easily misused by the opperator, very low pressure is all thats needed if you can't manage without one,
a very useful bit of kit is the old garden spray, they are readily available at most super markets and DIY stores, I got mine for under a tenner from Aldi. JRS1
