E3 fault
Jan 18, 2025
Hi, left the caravan with battery a few months. Removed battery and hooked upto electric to keep heater on. Issue I’ve got now is the control panel says e3. It’s a swift europa 2008 Apparently it’s a comms issue . All breakers are on. Would this be a knackered controller? Any help would be most grateful. Thanks
Nov 30, 2022
1,859
1,704
2,935
Have you tried a Google search to see if anyone else has had tge same issue? Could save yiu a lot of grief.
Jan 18, 2025
I have mate, unfortunately most issues go towards a different model and a simple reset on the fuse box which this hasn’t got..
Nov 30, 2022
1,859
1,704
2,935
Try actually disconnecting both the control panel and the heater unit from the 12v supply, bit like control/alt/delete with a computer. Got to be worth a try at least, just leave them both disconnected for a few minutes.
