Good evening all,
I’m looking for some advice with my 12v electrics.
Caravan: 2006 Abbey GTS Vogue 415
My leisure had gone flat over winter (silly mistake I never removed it to charge). I have replaced the battery and now I have an issue.
The 12v system works and all lights work fine when the AC50 is switched on, battery indicator shows in the green. If I switch off the AC50 then I get a clicking noise from around the EC200 panel, quite a rapid click about every second. Sounds like a relay rapid cycling. I’ve not investigated further at present. This continues regardless of the EC200 rocker switch position (car/van/off) position if I turn off the AC50 power switch.
I’ll be going back next weekend to investigate further, is there any advice on what to check or consider?
Thanks in advance.
Thanks in advance.
