EC450 power supply removal
I have a Moonstone caravan and i amgoing to fit a solar panal and need to run the wire behind the power supply unit.
my question is as anyone removed the power from there carvan to get behind it. i do not want to conent any thing to the power supply i need to get behind it to feed the wire down and would like to know if i will encounter any problems with doing this.
Thank you all for taking the time to read this.
If you take it very easy and take your time you should not have any problems.
There should be enough cable length to allow the unit to slide out, but care is needed .
Obviously ensure all power is OFF before starting.
Thank you for you replay. all power will be off as i will disconnect the battery first.
just need to know if it comes out ok with out to much trouble.
thank you one more and stay safe
