Hi all,
I've got a problem with my caravan habitation lighting. On the 12v circuit one of the led strip tapes (around the sunroof on a Crusader Tempest 2016) had a loose wire. In trying to re-solder it I've caused a lot of problems. Now all of the lights in the lounge area are dim and if I turn the nearside awning light on and then the offside awning light on, the nearside one goes out! The offside one is one dim, even when it is switched off!
I am thinking I may have shorted the led strip and so blown a relay. Does that sound likely? Also, how do you get to the relays? Are they behind the fuse board?
Many thanks
Iain
Many thanks
Iain
