I have a Coachman VIP (2009) and bought an Elecsol 100Ah battery in July 2011.
The caravan is in a storage site with no electric hook-up so I have attached a small solar panel to keep the battery topped up (I checked with Elecsol and they said that there was no problem in doing this).
When the van is in store everything is switched off and the 12v Master Switch is in the OFF position.
The only current being drawn is for the alarm and Phantom Tracker - a miniscule amount according to Phantom.
That amount should be more than covered by the solar panel trickle charge.
I check the battery every six weeks and take it home to top up if it is showing any sign of discharge.
Last Januaryt the battery had failed completely and would not take a charge. I contacted the supplier and they told me to send the battery back for tests and they would replace it if it was found to be faulty. I sent it back at a carriage cost of around £20 and they did decide to replace it, but would not refund the carriage cost (so much for buying something heavy over the internet.....)
However the replacement does not appear to hold a full charge for very long and the solar panel seems to have no useful effect.
We are now away on holiday with mains hook-up and I am finding the the 12v lights flicker a lot and will dim if another light is switched on (especially the awning or bathroom light) or if the water pump operates.
I have had the van tested during service to check that there is no current being drawn from anywhere when everything is shut down and that the solar panel is supplying a trickle charge to the battery. The battery charger is also operating correctly when we have mains hook-up as far as I can tell.
I'm beginning to feel that an Elecsol battery isn't man enough for caravanning.
I would be gratefukl for any thoughts or advice. Do I just write off the £100 cost and get a "proper" battery?
