Electrical connect atc 2 to swift
I am going to fit atc 2 from alko to a 2020 swift eccals x850. Believe the electrical connection is available on Sargent c44 fuse board with connection FB5 this is a connection for some type of 2 pin push on connector. The wireing on the alko is 3 spade connectors live feed live return and an earth. Does anyone know how to connect this up please
That’s unusual?
Normally the Al-ko ATC is wired via the tow bar electrics , totally independent of the caravan system.
, My ATC receives its power from the 13-pin plug on the towing vehicle, specifically through a pin 9, which corresponds to pin 4 on the 12S (older 7-pin) socket.
It is a live feed without the car ignition being turned on.
That’s unusual?
Hi the tow bar electrics connect to the c44 fuse board directly with a plug that connects to the board and on this board is the FB5 socket
Sorted got a
Genuine TE 2 Way Universal MATE-N-LOK Electrical​
Wiring Multi-Connector Kit Supplied With Terminals off eBay the male part fits perfect with the PB5 terminal on fuse board. Taped up live return on alko wiring and connected earth and live feed to FB5 terminal and all good and working properly.​
