- Mar 17, 2020
- 553
- 422
- 11,135
Any clue from the following please:
1. Changed battery on caravan.
2. Connected mains lead to van - 230 volts systems fine in van (sockets/lights etc) all working.
3. Pushed black button in on under-seat fuse/charger etc box but no green charger light. Amber heating/hot water lights when pushed in and battery showing 13.6 v on over door panel.
When I push the charger light switch in the reverse polarity indicator flashed briefly and a light appears next to the relevant fuse (25 amp) as shown in pic. I've checked fuse and ok - even swapped it for another to be sure.
Question please.
1. I understand that the charger light should illuminate even if no charge is required by battery - i.e. it stays lit up constantly? Is this the case? Not something I've ever noticed but certainly the over door panel shows no 230 v coming into van when just charger set to operate.
2. I've never before noticed the bright green light illuminated against the charger fuse before - does it indicate anything?
Any further advice.
Strange thing is van was serviced a couple of weeks ago and all well then I presume.
Question please.
Any further advice.
