- Jan 23, 2023
- 4
- 1
- 15
Hi there first post, so hope this is ok.
i have an 2005 Elddis Crusader storm. Not my first caravan, but still only a few years experience.
we recently bought this and all was fine when checking it over, hot water, heating worked all good. however since going out in it i have had not end of problems getting things to work.
Going to check the PCB for heating, fire makes a noise but doesnt put out any heat, Hot Water light comes on the board, but for some reason can only get water from onboard tank and not the heater, bit stuck with that one. i seem to have a lot of switches that have been put in after caravan left factory.
my main concern and something i havent encountered before. the Electrics act "Weird" for want of a better word. im on a 16amp site, so good there, say, if i have the TV on, the lights or water running out of tap, something else will switch off, normally the radio. The electric doesnt trip out, just one of the items will stop working, if i switch off an item, the other item turns back on. Every electrical item tha comes on too will dim the lights ever so slightly for each electrical item.
Doesnt seem to be anything power hungry and mainly happened during the summer when the heating was not needed. Used it last week with a 2000 watt heater and it worked fine with TV running, but had to have lights off.
any ideas?
thank you
Stuart
any ideas?
thank you
Stuart
