Electrical query
Aug 17, 2015
6
Hi
I'm looking for advice about electrics.
I need to test the supply on a caravan I've bought to renovate. Is this a simple job that I could do myself or would I need a specialist?
Any advice welcome.
Andy
4,462
Hello Andy,
You don't tell us very much, for example are you concerned about the 12V dc or the 230 Vac systems. You don't tells what your area of expertise is are you an electrician? I suspect not, otherwise you would know the answer to your question.
If you are concerned about mains electrics or gas systems and you are not competent and confident at dealing with them, it's best to leave them alone and get professional help. After all it could be you or your family's safety at stake.
Mar 13, 2007
1,750
andypg said:
Hi
Any advice welcome.
Andy
hi Andy. I would not wish to pre-empt any answers you may receive later, but your question is unanswerable in it present form, :whistle: so many things are variable, it depends on.
age of van.
level of sophistication in the electric circuits.
compitance of the tester
having the right tools
and having an understanding of how the systems work.
if you fill all the criteria yes it is simple, if you don't no it not. I have done a few re-wirings and can tell you if it's fine and you just need to check things, a multimeter is all you need, if you find many faults however it easier to do a complete rewire that you know works rather than fix unknown faults, either way this could be expensive on a old van.
lastly it also depends which circuits you wish to test,
sorry mate there's not really enough information in the OP to give a fuller answer.
4,462
Yes Colin, because as you pointed out yourself the poster has not provided enough information, nor expressed his competence in the field.
Mar 13, 2007
1,750
when the OP comes back with more information may-be someone will be of help.
until then "no comment" not getting in to all that again. :whistle: :whistle: :whistle: :whistle:
Parksy
11,904
2,400
https://tpc.googlesyndication.com/simgad/9477200985930578428
If PCv can allow the above pop up why not have a Prof pop up explaining the safety issues of gas and electric DIY :) B)
It would save the Prof's fingers from all the typing
I can't do pop ups but if the Prof would care to submit a synopsis which includes common gas and electric caravan-related safety issues I'd be more than happy to turn it into a 'Sticky' for the Technical message board which would allow a simple url link to be given whenever it was needed.
Aug 17, 2015
6
Thanks guys, I'm not an expert but can do a little bitof wiring, I have zero experience with caravans so was just seeking advice. I don't know the system or voltage info as it's a pretty old van and I'm still trying to find original info. If it's too difficult I will get a pro in!!
Prof John L, to save you fingers next time and don't reply. I am new to this and have no experience so was just trying to see what advice was out there off more experienced people. Your post as well as being unhelpful and patronising makes me think I won't use forums in the future. I'm here to get advice not be treated like a fool.
Andy
937
Hello Andy,
The wiring in caravans is not extensive but it is difficult to get to in many cases due to poor access and the makers hiding it away in very awkward places.
You will almost certainly have both 12vDC and 230vAC, but without seeing the van it is difficult to say how much of each.
At a guess you may have two 230vAC lights at the front end of the van, plus 230vAC to any sockets, battery charger(If in fact one is fitted) and 230vAC to power the fridge(again if fitted)
Most of the other lights will be 12VDC as will the water pump, toilet flush.
First thing to do is trace each wire and see where it goes, with any power turned off just in case there is a problem with any of it.
You can do this with a multimeter and extensions to the probes, or by sight and feel.
Once you know what is what, and whether it is 12v or 230v, you can check continuity and cross continuity with a multimeter.
For insulation testing and RCD trip testing you need special equipment which is expensive to use on a one off basis. Also, unless you know what you are doing with insulation testing you can do a lot of damage as you would be sending 500v down the cables.
If you have a look and if needed, post photos of the bits you are not sure of, and if it seems to be beyond your comfort range of jobs, it would be better to get an electrician in to do the testing and advise on what needs doing.
One thing to remember is that the ordinary twin and earth solid core cable as used in the home is not allowed in caravans, it must be multistrand flex of the appropriate size, 2.5mm for power, 1.5mm for lighting.
4,462
Andy
Hello again Andy,
I'm sorry if you feel my post was patronising, It was not intended to be. Personal no, factual yes.
Please bear in mind that as a new poster on the forum, we have absolutely no idea of what experience or skills you may have unless you tell us.
Without that information we do not know at what level to set our answers. so its prudent to assume the questioner is inexperienced. When it comes to matter relating to hazardous systems such as mains electricity it would be irresponsible to offer advice on practices that involve specialised test equipment or processes that DIYers simple do not have access too.
