- Aug 29, 2007
- 8
- 0
- 0
Wonder if you could help ? I have a Tabbert Jeunesse 515 HTD 2000 model and have a problem with the electrics. When plugged into mains i have 240 volts in van but have no 12 v circuits working ie lighting , toilet water pump, water tank .What would you think could be the most likely cause ? The battery , as i don't think it's ever been changed or the charger or even a problem with the fuseboard ? With it being German i'm struggleing to understand the wiring. The indicator light on the panel took an age to go green also but the charge indicator shows it charged ..........HELP ....!!
Will any type of 110 AH battery do or is there one recommended if it is that ?
