Hi all... Having a great holiday in Cumbria, enjoying the sunny weather, got back to a puddle instead of an ice tray ..... The fridge has packed in
ProfJohnL said:HI,
I have a suspicion that as the fridge is now 20 + years old the mixture of refrigerants it was originally made with may have leaked or lost their potency and means the fridge struggles to drop its internal temperature enough.
If the refrigerant has completely gone, then it wont work on any of fuel sources. another possibility is the 230V element may have failed, in which case it should still work on gas. .
sgtangel said:Thanks for all the responses.
After 2 hrs there was still no noticeable cooling, but I hedged my bets, left it running overnight and it is now cold - I suspect a faulty 240v element may be the cause, likely due to a combination of the age of the unit and the warm temps yesterday. We have sourced a 240v camping fridge from Halfords as a backup, but suspect a replacement fridge is on the cards to avoid any repeats.
Cheers all ......
EH52ARH said:Prof, a questiom, you say about not realistically regassing the fridges, Why ?
Because , they are soldered pipes etc, I can see that. And the cost of changing joints to "Screw on " regassing joints, against a new fridge,
I Would go for a new fridge. .
SG. HOPE your rest of the time goes ok.
Hutch
Raywood said:WE had an Electrolux fridge in our Eldiss which did not work when we bought the caravan new about 13 years ago. Electrolux suggested that they could in fact replace the works without changing the fridge itself although this did not happen as the dealer just swapped the fridge with one in a stock caravan. If the fridge is broken it might be worth checking if the works can be replaced as a cheaper alternative although I am not sure just what they would have replaced..
