- Mar 14, 2005
- 19,272
- 4,459
- 50,935
You do not understand how the condenser dryer works. In a conventional tumble dryer, the air is heated to lower its specific heat which allows it to collect moisture from the content of the drum. It then vented the mist warm air which was usually vented out side to prevent condensation problems inside the house. All the heat energy in the warm moist air was lost to the out side.Surely a heat pump tumble drier has to extract its heat energy from somewhere, and in most cases that will be from within the home?
That means the home is cooled if that energy is not recovered somehow, probably meaning setting up a circle where the home heating has to work harder to recover set temperatures.
On the face of it, a bit robbing Peter to pay Paul situation, at least in the colder months where home heating is needed, the very colder weather the tumble dried would be used rather than outside drying?
Condenser dryers rather than vent all the moist air outside, instead it is passed over the evaporator coil of a closed loop refrigerant system, collects the heat from the air cooling it and causing it to drop its moisture into a collection tank. The air is then recycled over the hot condenser coil of the refrigerant system, which warms the air again before its passed through the drum to repeat the process. The drier might simply rely on the heat generated by the refrigerant compressor or it might have a modest heating element. This process will use a lot less energy than a conventional drier, and certainly wont cool the room its operating in.
