EV charging is changing.
Nov 30, 2022
1,716
1,555
2,935
1000w charger? Get on! That the same as a TEN bar electric fire would use
Thats going to need a cable as thick as your wrist I would think! Are there ANY in existence yet?
3,931
Some mix up of units here
Now possible to charge an EV in 5 mins for 250 miles. If only you could find a 1000 kv charging point.
I'm sure you mean 1000kW not 1000kv
1000W is only 1kW, A TEN bar electric fire would conventionally be 10kW
The 1000kW would actually be 1000 electric fires
As for the size of the cable required, yes it will be large but not as big as you think as these big kW capable chargers will be working on 800V or higher architecture which keeps the size of conductors down.
350kw is the max of any installed in UK.
That might be the case at the moment, but it could increase in the future.
8,099
I’m sure that it will go above 350kw with the developments being pursued by BYD and others, but 350kw is the max rating at present in UK.
4,633
I wonder what the cost will be to top up the battery per kw? Probably as much as a litre of petrol?
4,728
How much and who will fund the cost of the infrastructure? Can the Grid cope 🤔
1,960
In the PC mag there was an article about Instavolt ( I think, can’t be bothered to get it to check) putting caravan accessible spaces on one of their big charging plazas. A good move imho as not being able to charge while towing is one factor in limiting EV use. Of course 1 charging centre is not going to be a game changer yet, but an interesting step.
8,099
I’m pretty ambivalent about it, as at present the very high charging rate has not been rolled out even in China. But I’d expect it would be attractive to owners of premium cars designed for faster charging.
My grandson has just had his order for an ID7 Tourer AWD cancelled by VW. If he wants to reorder it’s at a higher price with less specs unless added to the order. So he went over to the Tesla showroom in Bristol last Saturday to look at the new Model Y. Seems Tesla are doing very good deals via Octopus probably to get sales up. So he’s now driving a Kona EV from Octopus until the T car arrives in June. Strange times in the motor trade.
Sam Vimes
2,245
1,776
Good question.
Add to this the push towards Heat Pumps and now the AI bit barns being constructed are going to add considerably to the loading.
I've read that some data centres are being refused planning permission because the localised infrastructure can't support the power demands.
  • Wow
4,728
Have Tesla redesigned their dashboards? Ie done away with everything controlled from a massive TV touch screen whilst you drive🤔
8,099
It is still a large screen and no obvious buttons/switches, although he adapted to his previous Model Y, but he says it's nicer to sit in than his previous one which he parted with last year. He was reluctant to go back to a Tesla and really frustrated that VW cancelled his order, but happy that his lease will cover any "protest' marks that may come his way.
4,728
I was curious to find out if the latest “ mobile phone”legislation had impacted the massive complex Tesla screens , whilst driving
4,633
Apparently no need to touch any screen as you use voice commands. Being old fashion I prefer to flip through the screens, but when stationery or gat I get OH to flip through them however the Lexus only has about 7 sub screens.
  • Wow
4,728
The XC40 Recharge latest. Fully charged before leaving Harrogate .Down to 20% needed a charge at Worcestershire Services.
They had a new 350Kw charger waiting .
7 minutes of charging took her from 20% to 45%, enough to reach Royal Wootton Bassett. Cost 79 p per Kw.
Now it’s spring the range is vastly better than last December. This weekend the usable safe range is circa 180 miles.Mostly 70 mph on motorways.
April 2025 all business use around NorthYorkshire needed 10 full charges , all,at home off peak. Actual total cost a miserly £22.48!
8,099
Tempted ?
4,728
I was thinking more as a Cee’d replacement
Not since they fixed our headlights👍.
The Cee’d does a regular 200 mile return trip,2/3 times a month . But you never know. It’s not off the possibilities especially the way the EV prices are dropping.
