FA O Parksy
Parksy
Hi Mr Parksy,
Just a quickie, is there any way you can give us advice on supplying links,
ie; When we supply links the full address appears, but you Mr Clever Clogs have the two words Click here, can you show us thicko woosie's how to convert it?
Or indeed you/Haymarket might have there reasons not to let us loose on this, if this is the case then I will understand.
PS Dont Click on the Click here it wont work!!
Please read the updated information on how to add a link using a much simpler method here
Hi Kev
There's no mystery or cleverness, I ought to have posted some instructions on how to make simple links before so thanks for the reminder.
If we take a link that you posted in another topic yesterday:
http://www.ebay.co.uk/itm/Caravan-Convoluted-Waste-Pipe-Hose-29-0mm-PER-METRE-/250793700612?pt=UK_Campervan_Caravan_Accessories&hash=item3a64782d04
Along the top of the comment box you will see a chain icon.
Copy the link that you have added to the comment box and when the text has been highlighted in blue you will see that the chain icons have been activated.
Left click on the left hand icon which shows the unbroken link and a dialogue box will appear (the other severed link icon is to unlink text and does not concern us)
Paste the copied url into the url box (top one)
In the Target box click the drop down and select Open Link in a New Window (It's important to do this)
In the third box marked Title add a word or words to show what the link will be (such as click here)
Ignore the bottom box marked Class.
Click on Insert
Your link will appear and it will seem no different to the original except that it will open in a separate Window.
To condense the link down to a word or phrase chosen by you:
After you link has reappeared click Disable Rich Text (bottom left of comment box)
You will find your link and the post written in HTML (hyper text markup language) and will look similar to what is shown below:
<p><a title="Click Here" href=" http://www.ebay.co.uk/itm/Caravan-Convoluted-Waste-Pipe-Hose-29-0mm-PER-METRE-/250793700612?pt=UK_Campervan_Caravan_Accessories&hash=item3a64782d04" target="_blank"> http://www.ebay.co.uk/itm/Caravan-Convoluted-Waste-Pipe-Hose-29-0mm-PER-METRE-/250793700612?pt=UK_Campervan_Caravan_Accessories&hash=item3a64782d04</a></p>
Don't be put off- the next bit is easy!
Ignore the <p> because these do not concern us. What is shown is actually your link written twice inside some brackets which are <a> at the start and </a> at the end which just show the start and the finish of the link.
Look back from the last </a> closing bracket and you will come to the word blank"> somewhere in the middle of your link
Leave the final </a> bracket, left click immediately to the left of it and delete the second part of the link until you come to blank">
You will be left with
<a title="Click Here" href=" http://www.ebay.co.uk/itm/Caravan-Convoluted-Waste-Pipe-Hose-29-0mm-PER-METRE-/250793700612?pt=UK_Campervan_Caravan_Accessories&hash=item3a64782d04" target="_blank"></a>
Insert whatever words you want to be seen on the forum between blank"> and </a> (click here or something similar)
Enable Rich text again, continue with your comments or click Save and your streamlined link should appear.
Job Done! Clever Woosies Click Here
Tip: Sometimes it can be difficult to add a copied link to a line of forum text so paste it a line or so below before following my instructions.
When you have done, click Preview, wait a couple of seconds and adjust the position of your link to wherever you want it to be.
Copy the Practical Caravan url from your web browser and practice turning it into a link which is shown as Forum and opens in a separate Window
Parksy - Moderator said:
Hi Kev
Thanks for That Parksy, think I'll have a go tonight when I've got 5 hours to spare
Gee.... thought you said it was simple!!!
It's much easier to do than it is to describe or to read about
Try a simple url to try the link such as the one for Practical Caravan
http://www.practicalcaravan.com
Copy, insert in dialogue box and select 'open in separate window', Insert and disable rich text :
<a title="Forum" href="http://www.practicalcaravan.com" target="_blank">http://www.practicalcaravan.com</a><
Delete the part highlighted above in red and add your own words :
<a title="Forum" href="http://www.practicalcaravan.com" target="_blank">Practical Caravan</a>
then click on Save
The link will just show up as Practical Caravan
You're NUTS Sprocket............. But I did giggle
Trying tonight to put every thing back on my computor (laptop at home) last night it crashed and burned, IEP9 just dissapeared and I could'nt do any thing with it, so our teccy at work erased everything and I'm now on Firefox, see how this goes.
Now where's me little Giffy things
Sproket said:
I suppose that you would like the instructions in photo format ?
Like this here ??
Got most of it but when I Disable rich text there is only one copy!!!
Will look again tomorrow as my brain is now frazzled.
Photo's would be good though for thick woosies, cheers Sprocket
Gagakev said:
Like this here ??
I think you may be getting stuck with this part ?
When you highlight the text in the box then click on the left hand chain link a pop up box will appear click the text in the box what says Target Click open in new window then put a word in the box below marked Title
then click Update & then click Disable rich-text, below is what is shown.
"http://www.practicalcaravan.com/forum/our-website/fa-o-parksy" target="_blank">http://www.practicalcaravan.com/forum/our-website/fa-o-parksy</a></p>
Delete the text in red only......... & it will look like this below
"http://www.practicalcaravan.com/forum/our-website/fa-o-parksy" target="_blank"></a></p>
Then in between the red > < is where you put your word ie: parksy
"http://www.practicalcaravan.com/forum/our-website/fa-o-parksy" target="_blank">parksy</a></p>
Then click Enable rich-text & you will see parksy turned into a clickable link in another window
After a while it will become dead easy to...... do
