- Mar 17, 2020
- 528
- 390
- 11,135
Interesting comments regarding choice of "mode".
Our Santa Fe has "Smart", "Comfort", "Eco" and "Sport". There are also "paddles" that I may rarely use and I doubt influence consumption unduly.
There is a distinct performance increase with "Sport" and other parameters beyond performance are said to be influenced (weight of steering for example)
Before buying my last Santa Fe I was firmly under the impression that for towing "sport" was the best mode and certainly if speed or throttle response are required it delivers very noticeably.
However, for most driving, including towing, I use "Smart" and the car decides which mode to use. (I can see the current mode indicated).
I've never used "sport" for long distance towing, nor for non towing for that matter. ( Except briefly if I want to quickly overtake for example). It does perk things up but the higher revs before a change and any other "changes" it makes must mean consumption will take a hit.
"Comfort" I've never used but I have tried "Economy" whilst towing. The main obvious difference between this and other modes is the higher ratios it uses - delays changing down. Whilst this might suggest a better fuel consumption I've never noticed any difference from "Smart" but there again, to make a meaningful result would require all the variables to be taken into account. I'm not a fan of mpg claims to be honest.
In my case the ratio of caravan weight to laden car weight and performance is good in all modes. My weight ratio in "real" terms is almost exactly 60% which allows for easy progress.
Bottom line though, has to be that dragging a big box on wheels around requires more fuel and, as caravanners, we are aware of that. As for actual mpg figures for me my average is close to 25 mpg but has been as low as 19 mpg and as high as 31 mpg when measured between fills.
The variables are significant and since these figures are from my own driving then the influence of my "style" is significantly reduced.
I would love to be able to claim figures of 30 mpg, 35 mpg etc that others seem to achieve - but I can't!
