Feeding cable into caravan for 5G antenna while parked up only
3,818
1,543
Has anybody knowledge of actually what cable or cabling is involved? Would make giving targeted advice way more specific.
Edit: a quick look indicates some are WiFi some Ethernet, probably using PoE.
Neither seem to me to be challenges on a temporary potable basis, more a challenge if a permanent fixed solution is envisaged.
905
564
1,135
When I used a satellite dish it came with a adaptor cable, very thin cable that routed through Window.
8,169
I used Rockboard “ flat cable” for tv and sat. Different cables of course. If OP knows the cable spec for his needs then a quick search will give options. Just include “flat” in the search.
3,818
1,543
Phone on roof in plastic bag and use wifi. No need for any cabling. Simples.
Much my solution, but then its "tethering" the mobile not using a dedicated MiFi unit.
______________________________________________
Re cabling, it's going to depend on the device the OP is using, which so far I have not picked up on. By inference, the mention of a cable implies its not a device with onboard powering and or wifi data transmission.
13
13
So for reference, it's a ZTE U50 MiFi 5G device that has additional ports for external antennae to improve reception of the mobile signal in weaker signal areas.
Rather than clutter the roof of the caravan with an AVTex aerial and router, which seems like a far more expensive way of achieving the same thing, this provides an easy solution within which we can switch SIM cards easily dependent on the local dominant mobile provider.
Whilst I understand that for some, any time away from home is an opportunity to completely disconnect, for others we use it as an opportunity to work from somewhere different and take the option outside of work time to investigate and discover a new area, usually around a long weekend!
Horses for courses, as someone else might have said...
4,673
If signal is poor, then I think there is nothing much that can be done, but open to correction?
3,818
1,543
Any details on these ports, I am not finding any info on this?
I find there can be quite a difference in the signal pulled in between my phone in the van, an aluminium clad one, or outside, much depends if a window is in line to break the van's Faraday cage.
4,673
We open one of the skylights and place the phone on the roof when we are in an area with poor reception. However if you are in a dip, nothing much you can do to stream to the phone.
At East Fleet farm in Weymouth we had that issue and not much we could do about it. Strangely when down in Brean in Somerset where the area is flat, the signal can be poor on many campsites? Apparently people in the area haven been complaining about this abnormality for some time?
Feb 13, 2024
905
564
1,135
Don't know if relevant but I could not get signal for my TV, my brother had a cheap magnetic small aerial and stuck it on roof of car, hey presto 100% crystal clear picture. About £7 from the bay of plenty.
4,673
Sometimes a wire coat hanger will work just as well. :D
May 20, 2024
13
13
That's really part of it. We're a Bailey, so the AluTech potentially presents reception problems.
3,818
1,543
With all brands you will have the same issue.
Not so where the walls are composites etc, its metals, sheet, foils and certain meshes where the "Faraday Cage" issue lays. later Alu-Tec were I thought a grp skinning, foam sandwich.
