I am in the process of fitting a car rdaio to my carvan. I have two questions
1 The fitting instructions say that a strap should be used at the back of the radio to give a secure earth to the vehicle body. As this is not possible can I rely on the normal negative lead to the battery to give me a good earth.
2 The fitting instructions state that I should not connect the speaker negative wires together and that they should go to the individual speaker. I have a pair of computer speakers with 8ohm impedence which should be ample for my needs They are joined by two leads that are in turn together in a small jack plug which I am reluctant to break into as the leads are miniscule. I cannot split them so I intend to use a jack plug socket to connect the speakers to the radio but as the socket has only three connections,one for left speaker one for right speaker and the negative return, this will entail joining the negative leads from the radio. Will I b#==$^ any thing by joining the negative wires
